1964 Corvair 95 Van 110HP 4sp FOR SALE Must GO
(Corvair ads you find on other sites can also be discussed here, i.e. ebay, craigslist.)
Goop Of Oil
Post by Goop Of Oil »
FOR SALE in Damascus Maryland. Must GO Price $5900.00
This 1964 Corvair 95 Van was the inspiration for this post back in 2015, 10 years ago Today;
viewtopic.php?p=67682#p67682
NEW Gas Tank and Dual Master Cylinder, wheel cylinders, brakes, hoses and brake lines.
Bill had moved from where this install was done and then the Van sat garaged. It Never had gas or brake fluid put into it since the tank install.
In 2016 Bill pulled the motor, and trans to reseal it and refresh the shrouding as mice made a home in the engine and heater box. Then it sat garaged again.
Two weeks ago we started work on it.
First thing we did was clean up the mouse nest on the engine over #6 cylinder and remove the heater box and REPLACED IT with one from the Corvair Ranch.
All shrouds were painted.
Roger Parent accelerator linkage was installed.
New diff yolk axle seals and new U-Joints installed.
U-Joints & Heater Box installed
Engine has been installed and is now running and the brakes are working.
Bill writes;
After college I started to do a driver restoration and upgrades in the late 80's early 90's. All the old paint was stripped off down to bare metal prior to painting. The engine (original VB block) was pulled and rebuilt with new forged pistons (+0.030?), new cam, main and rod bearings and crank, rods, pistons, flywheel pressure plate were sent out for balancing as well. This was by far the smoothest running Corvair engine I'd ever seen short of a race motor.
The dog legs have NO rust. The body on this Van is Very straight and only has a rust hole on the left rear panel near the battery as seen in one of the pictures below.
OH Yeah. It has a NEW Battery in it!
Check out the pictures and if interested I can give you Bill's contact info.
He is moving again and has no room for it. WELL Worth the price. Spyder dash installed and he does have the glove box door also.
Must Go price is $5900.00
Located in Damascus, Maryland.
Switch bracket included for Spyder dash.
Spyder Dash switchs.jpg (33.03 KiB) Viewed 67 times
Running.
Running.
-------- Mark Holmlund --------
rcavictor
Re: 1964 Corvair 95 Van FOR SALE Must GO
Post by rcavictor »
Congrats on getting it to a running and driving condition - time well spent in moving it to the next Caretaker!
Great price and very tempting.. :doh:
Rob
- Cornucopia of Corvairs
Ocklawaha FL
caraholic4life
Post by caraholic4life »
I went to Bill's home in Damascus MD. two weeks ago and spent a few hours visiting with him and Mark while assisting some with some of the work I was able to accomplish while there. (it wasn't much though).
There is some surface rust in a couple places and a few other issues that should be dealt with like the area below the battery box but, the van is in my opinion well priced for what it is.
This van would make a decent driver for someone that wants something serviceable enough to use while attending to what would need done to get it back to it's former glory. Take a look at the customized front Grille, it is well done.
NOTES:
I did see the Jr West Coast Mirror pieces and the rear grille inside the van. The front seat will need recovered but in the mean time, I saw a new generic seat cover in a box that should work until that gets done. The windshield appeared to be in good condition. IF I were in the market for a panel van, this one would no longer be available.
Goop Of Oil
Re: 1964 Corvair 95 Van 110HP 4sp FOR SALE Must GO
Check out the Auction of this Corvair 95 Van at this link.
https://gregorysauctions.hibid.com/lot/ ... y--corvan-
Ends this Friday evening around 7pm. It will be extended by 2 minutes if a bid is placed within the last 2 minutes. It could stay open through the Weekend?! ::-): :chevy:
Return to “Vehicles For Sale”
