All four carbs have the little spring (float control spring).
The two secondary carbs have a little wire,that clips/goes around the head of the needle and then the other end goes through a little hole in the float arm. Kinda like a needle retainer.
The two primary carbs do not have this little wire clip for the needle.
Shouldn’t all four carbs have this little wire clip (needle retainer)?
