Brake Drums - 1964 Monza Vert
Imnvegas
Post by Imnvegas »
I have a question and I am not sure if this is the correct place to post.
Are there drums from other cars that are interchangeable for a 64 Monza? I know other cars use the 4 X 4.5 pattern. I am going to do a complete brake job and I would prefer to find new drums. used turnable ones can be had but I would like to try to find new.
All my searching for 1964 corvair drums always shows the 5 bolt pattern. What is up with that? Bendix and Centric both show that EM's are 5 bolt.
I am very new to corvairs so be gentle on this vairmoron...LOL
Thanks
Rob
Re: Brake Drums - 1964 Monza Vert
They are certainly 4 bolt:) New drums are not readily available. The stock rear drums on the 64 were finned. These can be particularly hard to find turned or new. 1960-63 rear drums will work just fine instead, they are the same but not finned. The front drums must be 64, they are not directly interchangable with the 60-63. I suggest not spending alot of time looking for NOS (New Old Stock) drums. A good set of used turned drums should be fine. Be advised that many of the brake shoes for the early cars are a bit over sized anyway, requiring sanding down or turning of the drums for a good fit. So a new drum might have to be machined significantly anyway.
By the way, the best place to post mechanical questions is in the Mechanical/How to forum, but we are not too picky here and will likely provide answers (many even useful) regardless of where you post.
It is always hard to find anything "Corvair" in local stores. Except for oil or gasoline I don't even try.
Here is some good brake configuration and performance information for Corvair brakes...
http://autoxer.skiblack.com/brakes.html
New brake drums for a 1964 Corvair...
NEW: CX4722 Out of Stock
Clark's Corvair Parts Online Catalog - Page: 142
http://www.corvair.com/user-cgi/catalog ... N&page=142
FRONT Part number C8164 (Regular): TURNED BRAKE DRUM 1964 FRONT*CORES MUST BE REUSABLE OR NO CREDIT!!
NOTICE: Price includes core value: $65.00. You will be issued a refund of $65.00 when you return the used part.
Note: This part is not a perfect match for CX4722.
Weight: 10 lbs 0 oz
Catalog Pages(s): 142,U-22
Price: $ 102.80
Part number CX5018: FINNED REAR BRAKE DRUMS-1964-AFTERMARKET
Weight: 14 lbs 0 oz
Price: $ 99.00
Part number CX4721 (NOS): REAR BRAKE DRUM-FINNED-64 CAR
Weight: 14 lbs 0 oz
Catalog Pages(s): N-32
Price: $ 146.00
NOTE: Clark's catalog specifically says that 1964 Corvairs MUST have 1964 drums on the front end. It further states that 1960-1964 rear drums are interchangeable. They currently seem to have new rear drums in stock, but sound like they are chronically out of stock for new front drums. I would suggest looking over their catalog information. Click on part numbers for pricing and availability information. If you need clarification or want to discuss new vs. used, a phone call to Clark's might be in order. Main Office Phone: 413.625.9776
CORVAIR UNDERGROUND Phone 800-825-8247 or 503-434-1648 http://www.corvairunderground.com/
If you want to check with Corvair Underground and get current information and availability, a phone call is in order. Catalong an dpricing info online is out of date.
CALIFORNIA CORVAIRS http://californiacorvairparts.com/ Tel: (951) 284-3555
Indicates used drums only.
CORVAIR RANCH http://www.corvairranch.com/ (717) 624-2805
A good used parts source.
There is really nothing wrong with used, properly inspected and turned drums, and in many cases you may not have the luxury of an option for new drums. Disc brake kits are available, but expensive. Good drum brakes are perfectly adequate on the street. Recommend you discuss this on the phone with several of the providers listed above.
Imnvegas
Post by Imnvegas »
Thank you
It is as I thought. I was planning on turning mine or buying used. I just thought I would float it out here. I appreciate your feedback.
Rob
