kind of need a quick answer...
Honda750Guy
Post by Honda750Guy »
the gear shifter on my 64 corvair 3 speed is slack, something happened to it after the last time it was towed when i moved. what is going to be the most simple way of getting it into neutral to show an interested buyer / restorer that it runs?
Honda750Guy
Re: kind of need a quick answer...
nobody? i dont have a manual so a diagram or something explaining how i can shift the car into neutral from under the car would be great!
albowlly
Post by albowlly »
I suppose that you could crawl under with a pair of vise grips and manually shift it into neutral. You might have to remove the cotter pin to disconnect the shift tube from the transmission to accomplish this. Finding neutral would be a process of trail and error tho. :fingerscrossed:
PHX65CorsaHT
Post by PHX65CorsaHT »
Yes from underneath finding neutral should not be too difficult
Cave Creek AZ---75 Datsun PU, 82 Toyota Supra, 70 Nova,
65 Chevy PU, 72 Suburban,
96 4Runner, 06 Sequoia, 65 Corvair Coupe
