Oil pump primer tool/shaft
Kevireno
Post by Kevireno »
I am going to make my own oil pump primer tool/shaft.
How long does the shaft need to be?
Kevin
cnicol
Re: Oil pump primer tool/shaft
Post by cnicol »
I would just take the handle off the yellow screwdriver and call it a day. The oil pump is about 7" inside plus you need some room on the outside for your drill motor.
Plan B; strip an old distributor and use the shaft as an oil pump priming tool. This approach has less chance of damaging the accessory housing .
TimeMachineParadox
Post by TimeMachineParadox »
The better tool to make would probably be one from an old distributer.
The second bearing surface for the distributer shaft is the bore at the bottom to the oil pump. Running a loose screwdriver shaft around in there could damage that bore.
~Nick
Louisville, Kentucky, US
64 Greenbrier
vairchet
Post by vairchet »
This is what I use (make certain shaft is well lubricated):
Drill Motor Preoiler
TimeMachineParadox wrote: Wed Mar 05, 2025 11:47 am The better tool to make would probably be one from an old distributer.
AGREE!!! There are old distributors that folks do not want that you can strip down for a priming tool. All you need is the distributor shaft and housing. Not expensive and easier than trying to make a took that could damage the ALUMINUM bore at the oil pump housing.
Dennis66
Post by Dennis66 »
If you don't have an old distributor shaft and don't have access to one, al least round off any corners on the sides of the end of the screwdriver so they don't catch or damage the bearing surfaces.
vairmech
Post by vairmech »
No, No, NO! on using a screwdriver!
Anyone that wants a priming tool I e=will make them one, $19 plush the shipping. I owe one persone one and it has been long enough that he will get it for free!
Why no screwdriver? Where the oil pump drive is, is a bushing. If you score that or even shave it out the the distributor will not have a good lower bushing.
Ken Hand
248 613 8586
vairmech@aol.com
Corsa Past President
Corvanatics Prez
Ultravan Club Prez
Chair 2007 Detroit Convention
jimbrandberg
Post by jimbrandberg »
I use an old distributor with the body and everything but the point plate removed.
For some reason way back whenever I started using it I ground the teeth off the gear rather than just removing it. Maybe I didn't have a small punch to remove the roll pin.
