Result:
The color is pure RED. My camera made it look pinkish.
Here's what to buy for your inner lights:
https://www.amazon.com/gp/product/B08139XJ52
Easy 15 minute install. Wiring is self-explanatory. Ring fits behind the lens. I drilled a small hole to feed the wire through.
$13 to improve your odds when the guy tailgating you is texting.
I also have LEDs in the outer lights:
https://www.amazon.com/dp/B07RQCK9VK
Everything is VERY bright
(Thats running lights and turn signal)🔴🔴 Quad lights 🔴🔴 for brake & turn, easy DIY
67 Coupe Powerglide, Lynchburg, VA
Re: 🔴🔴 Quad lights 🔴🔴 for brake & turn, easy DIY
Thank you for the tips and links. I will probably pick up a set of the rings to help emphasize the brake light brightness, as my bulbs do now convey much difference between running and brake light brighness (especially if someone behind me isnt paying attention).
I was going to recommend using the bulbs I purchased from superbrightleds.com as they are "6 rows" of LED's tall, but your suggestion of the smaller (possibly/probably) less bright bulb will probably work better.
1965 Corvair Monza 2 door 4 speed 110hp motor
I say go ahead and recommend your super bright bulb choice and let us decide. With the inner led loops, did you add a cardboard tube to isolate the center backup light bulb?
Thanks guys!
Thanks guys!
Mine just arrived the other day, so hopefully its a project for this weekend.
I'm only going to connect the rings to the brake portion of the tail light circuit. I'll report back how it works out for me.
I didnt get time to play with the car this weekend, but did look at the lights when they arrived. How did you mount your rings? Did you just use the double sided tape they came with or something different?
