Page 1 of 1
Dual Exhaust Gt Style
Posted: Mon Jul 08, 2019 1:16 pm
by steve57
Installed 65-66 Mustang GT tailpipe trim rings so I could exit exhaust thru the valance.
Not completely done, still need to add muffler hangers and possibly some chrome exhaust tips or paint the homemade ones black for now. Had to do some body work to reconfigure the outside edge of panel.
Also need to finish up the the body work and repaint.
Re: Dual Exhaust Gt Style
Posted: Mon Jul 08, 2019 2:18 pm
by triumphcorvair
Dang. That looks awesome! What diameter hole and what did you use for bezels?
Edit: Ok, I see you used 65-66 Mustang bezels. I purchased one a couple of years ago from Drakes(?) It was bigger than the ones you used. I'll have ti dig it out to compare.
Posted: Mon Jul 08, 2019 3:46 pm
by steve57
I basically had to make template using the bezel as a guide. The holes are roughly 4ā€ x 5ā€ and trim as necessary to fit the bezel. I had to fill outer edge and bottom with sheet metal cut to fit and welded in place. More work than I anticipated but like the result. Exhaust tip is 3 inch. Had to make up some offset tailpipes to get it out the holes. Also glued in mounting stud at top
of bezel as it only comes with three, the way Ford designed it. Some of this idea came from www.autorestomod .com article on their 1967 GT build.
Posted: Mon Jul 08, 2019 9:39 pm
by triumphcorvair
The size of that bezel (4x5) sounds about right. I remember when I took it out of the package it seemed huge.
I'm currently designing a rear exhaust panel that will use dimple die cut holes, approximately 2.5". I plan on using 3" dimple dies for the exhaust. The pic is just for demonstration purposes only to show what a dimple die looks like.
Posted: Tue Jul 09, 2019 9:26 am
by GasDaddy140
Nice hot-roddy look! Love the green paint Corvair brother!
Posted: Tue Jul 09, 2019 10:32 am
by bbodie52
Here is a vairiation on your theme. It was a custom exhaust on an early model Corvair that had been customized to fit a late model rear suspension to the vehicle...
:clap:
Posted: Wed Jul 17, 2019 10:53 am
by steve57
Well this project is mostly done, put some SS exhaust tips on, repainted across the rear panel. I have not decided if I’m going to repaint the air grill silver, kinda like it body color.
Posted: Fri Jul 19, 2019 2:03 pm
by caraholic4life
I think what you did looks good but.....The 1963 through 1967 CHEVROLET Corvette had a similar Bezel that fit the body.
Utilizing the Corvette Bezels would have kept your Chevrolet, all Chevrolet, but that is just my opinion.
Posted: Sat Jul 20, 2019 11:54 am
by steve57
Thanks for the comment. Corvette parts are about $60.00 ea. Mustang $16.00 ea. Had to keep costs of mod below $250.00.
I’m retired now and wife says quit spending money. LOL šŸ˜‚
