Weird Stuff I Found in the Garage
Wagon Master
Re: Weird Stuff I Found in the Garage
Post by Wagon Master »
Google........Ford basket (bundle) of snakes.
Rotary FP46
Post by Rotary FP46 »
Wagon Master wrote: Sat Nov 23, 2024 7:26 am Google........Ford basket (bundle) of snakes.
Seems to be the same style of exhaust. Will have to ask some of the V8 vair guys whether this set of headers had a given name or model number.
Matthew Rose
Eldersburg, MD
1965 Monza
1966 Corsa Convertible
1963 Rampside
Many Tons of Parts
viewtopic.php?t=20137
Rotary FP46
83) Mystery Bracket
Found at the old house, with a handful of parts that may (?) have been intended for the Kelmark car. Not sure.
What is this thing?
84) Differential w/Angle Iron
What application would require the use of angle iron mounted in this way?
85) **EDIT: Gen 2 Chevy G-Series (V8) Engine House
Current, known Corvair applications? I think he wanted to make this the engine cover for the Kelmark car. That didn't end up happening, and the Kelmark car has been sold to Andria. So now there is this.
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Torskdoc423
Post by Torskdoc423 »
Matt;
V-8 Engine cover for 1967-69 G-20 van (both 90 and 180" wheelbase)
Larry
69 sportvan Custom (1).jpg (41.55 KiB) Viewed 852 times
61 Monza Cpe 84hp/pg 1973-76
64 Monza Cpe 140hp/pg 2024
2018 2500HD, CCLB, Duramax.
2019 Traverse LT 3.6L
Dennis66
Post by Dennis66 »
The angle iron was to anchor the rear face of the differential cover with a Crown V-8 conversion. I remember seeing that in the "How to Hot Rod Corvairs" book and always thought it looked sketchy.
RexJohnson
Post by RexJohnson »
The bracket looks to be a crown also. It would go between the front of the sag trans and the V8 bellhousing. The 4 smaller holes (2 on each side) would be for the small rods to the trailing arms.
Rotary FP46
Torskdoc423 wrote: Sun Feb 16, 2025 12:46 pm Matt;
Larry
69 sportvan Custom (1).jpg.
Thanks, Larry.
This cover is for Gen 2 only, and not Gen 1? I've never laid eyes on either in its natural habitat. Will be selling the cover (as well as everything else); need to be certain on application when I write up the ads.
Dennis66 wrote: Sun Feb 16, 2025 1:18 pm The angle iron was to anchor the rear face of the differential cover with a Crown V-8 conversion. I remember seeing that in the "How to Hot Rod Corvairs" book and always thought it looked sketchy.
Crown stuff. Nice. Someone is going to have fun with the pile that is forming up.
The guts of that differential have seen water. Wondering whether I should be taking a harder look into those for harder-to-find components.
RexJohnson wrote: Sun Feb 16, 2025 1:41 pm The bracket looks to be a crown also. It would go between the front of the sag trans and the V8 bellhousing. The 4 smaller holes (2 on each side) would be for the small rods to the trailing arms.
I wish I had some greater love for these things. As it stands, I feel like someone with a video game fixation who has just inherited a fully-stocked Snap-on pit wagon.
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
vairchet
Post by vairchet »
Rotary FP46 wrote: Fri Nov 22, 2024 9:27 pm 81) Mystery Sleeves - Packed in Wrong Box
I'm guessing sleeves for some sort of chassis bushing, but do not know which one. The box they were tucked inside of was for a non-Corvair body part.
I believe the sleeves were part of a replacement bushing kit(s) for front suspension strut rods.
Bushing Kit
Bushing Kit
Wagon Master
Yes.
For brake reaction rods.
Torskdoc423
Thanks, Larry.
Correct. Note the shelf on the sides. This made the V-8 (307cid) available as an option. The 65-66 didn't have that as they were strictly inline 6 units. The arch on the front at the floor is also more pronounced on the GEN 2. The floor on the GEN1's could be opened up to allow V-8 transplant along with the GEN 2 cover.
Larry
Rotary FP46
Spent some time, more recently, separating the wheels from everything else. Have almost finished consolidating those. While searching for the 5th center section for the set of Compomotive TF-300's, I came across these (together, in an open box):
86) Solid Flywheel
87) Odd Clutch Disc
Are these designs familiar to any of you?
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Rotary FP46
88) Early Rear Axles
Some are FC. Some are other.
For the 60-64 cars (wagons, sedans, and convertibles), was there only one length of rear axle? Were the left axles interchangeable with the rights?
Same questions regarding the FCs.
89) Odd Bracket
Is this familiar to any of you?
90) Stock Exhaust Manifolds
Questions:
Is the left-side manifold always the longer of the two?
Is there any version of these manifolds that is worth salvaging when one of the crossover pipe mounting flanges is broken - as is the case in the first photo below?
What is the tube running into the side of the runner on the manifold in the second photo below?
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Rotary FP46
91) One Rusty Lower...LM Face Thing
Given the location and extent of rot present in this section, is there any utility left in it?
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Torskdoc423
Exhaust manifolds:
Do believe one side is longer but can't remember which, think it might be Driver side. But I could be wrong (wife says 99.9999& 4/10 wrong). Hey, I got a 50/50 chance at it.
Little tube in 2nd pic is for the A.I.R. injection to exhaust on emissions controlled engines (67 and up?)
Broken mounting tab. No value in it unless you know how to weld cast iron. May be easier to salvage as scrap.
Lower fascia for LM (ROT)
If an owner is good at fabrication, and welding, he can patch it up and use it. I believe it's salvageable.
RexJohnson
That little tube is for the 60 choke system. There would have been a longer tube coming out of the back that went up to the air cleaner thru a rubber hose. Since the 60 manifold is for the right side that means that the long one goes one the left. 60 and some 61's have the manifold to cross over flange vertical instead of being on an angle. This would be for both manifolds. When they went to the hot air heater they angled the flange to better fit the new front head shrouds with the 4" hose outlets.
Post by Frank DuVal »
88. Axles are the same length left to right. FC has 5 lugs[studs] (and bigger bearing assembly) :tu: One axle length and bearing assembly for all cars, one for all FCs.
As said, 1960 has the vertical exhaust studs on the manifolds. The single little tube external to the manifold is the choke hot air system on a 60. The A.I.R. tubes are inside each exhaust tube, so three per manifold and much longer than the choke tube.
I MIG weld stainless studs to the broken ear manifolds when I do not have a good ear manifold. "They" say it can't be done except under perfect circumstances. Ha! My welding is not that good... :rolling: I would not buy one as I already have some. That broken off stud on the same manifold is no issue for me, I just grind the exposed part off, center punch as close to center as I can on the shadow of the now cut off stud, drill a new hole (5/16") and tap it 3/8-16. Trying to remove the broken stud here in the rusty east is futile. :rolling: Just consider the stud now part of the cast iron manifold.
Yes, long manifold is always left, driver's side, short one is right side. :chevy:
Wild looking clutch plate you have there! Nice groove cut into it, and the added ring. :think:
