Removing the belt drops allows the RPM down about 250 RPM in both drive and neutral. It still bellows black smoke in neutral.SpyderMan wrote: ↑Thu Oct 03, 2024 9:57 amThe vacuum advance needs a ported vacuum source. The instructions have it hooked to the carb with a short piece of brass or copper tubing. The oiler is the only thing that should be hooked to the ports in the base. I would just keep the vacuum advance unhooked for now. It is there to improve economy while cruising, turbo cars do not use one.SethThomas wrote: ↑Wed Oct 02, 2024 8:13 am The vacuum port on the Holley carb is plugged. There are 3 ports on the supercharger base/bracket. I have Vacuum advance on the lowest one by the intake. The oil drip is in the rear of the base, and on the same level as the 3rd port on the side between the Carb and supercharger (I figure the oil could have gone to either, they both tap into the same chamber)
I will try and look at my two Judson carbs and see if they have the tubing attached.
Do you know how much pressure your fuel pump is putting out? It could be overpowering the needle and seat.
I went ahead and plugged the advance.
The oiler is about 3 seconds per drop.
Yes the choke tube is tapped into the passenger manifold.
I have no Idea on my pump's output. It is a newly rebuilt original pump (only like 150 miles on it).
Adjusting the choke minutely send the RPM soaring or plummeting, and it is really slow to return to where it was (if at all). I'll see if I can loosen this up.
Honestly, I'm not sure how much I will want to put into this. I will keep fiddling for a little while. I'd like to be able to confidently drive it a few times. The build has been a fun experiment, but the noise is deafening. I have to wear earmuffs to be around the thing, and I'm fairly certain I would not be able to live with the noise long term. I can see why these are so uncommon.
