Duncan's 1963 Monza build
Re: Duncan's 1963 Monza build
Given time and continued success in this area, you might be able to run a small business overhauling Corvair steering boxes for owners all over the world!
Not much going on here. Got the steering gear installed.
Aligned all the marks up according to the manual.
Thomas Duncan
Houston, TX
1963 Corvair Monza with 64' 164CI 110HP engine.
1971 VW squareback
1966 VW Beetle
Owner of: www.vintagecarleds.com
Houston, TX
1971 VW squareback
1966 VW Beetle
I know, I know a lack of updates.
Just a little teaser of some things to come soon...
Still waiting on the crossmember to come back from the powdercoater.
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
Got my front crossmember back from powdercoating.
Working on assembly this upcoming weekend.
Looking JUICY.
Looking JUICY.
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
Looks GREAT!
I wish you were here! I have a 1966 Monza with a front end that would benefit from such craftsmanship!!
Bring it over.
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
Whew! That was quick.
A good friend of mine helped me assemble and install the crossmember to the chassis.
Factory primer (redish-orange paint) looks great! - I assume that's factory paint.
All new grade 8 hardware used.
Upper control arm bolts, and lower control arm bolts are not torqued to spec yet, as im waiting to load up the suspension.
New front suspension springs from clarks.
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
- flat6_musik
Stupendous! I don't know how I missed this thread!! WTG! You're going to develop a "perma-grin" on your first test drive, I suspect.....
Looks great! I am doing my front suspension also, just a few steps behind you!
Excellent work Thomas, that front suspension looks outstanding!
1963 Monza Spyder convertible
Welp.
Placed a large order at Clarks today for a new brake system. Everything is getting replaced. EVERYTHING.
Once I finish the front brakes, I'll spin the car around remove the engine and rear suspension...
100% rebuilding the entire suspension and brake system.
Front brakes:
Front brakes:
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
- flat6_musik
That's the kind of stuff that causes the endlessly grabby/pulling brake applications.
That probably explains the HARD PULL to the right I had when applying the brakes.flat6_musik wrote: ↑Sun Jan 16, 2022 7:59 pm That's the kind of stuff that causes the endlessly grabby/pulling brake applications.
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
Well,
I didn't pay attention to the brake shoe spring locations, or type of springs for the brake shoe retainers.
I've got: a regular non-tapered spring, and a spring with a coil taper/point to the end.
As for the retainers: Shallow retainer, and deep sitting retainer.
Does this look correct?
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
Installed the driver side front hub/brake drum today. Including new bearings / wheel seals.
Empty hub:
New bearing race installed:
Packed both bearings with fresh grease:
New wheel seal:
Empty hub:
New wheel seal:
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
Finished replacing the passenger side brakes today.
Before:
Leaking wheel cylinder:
New wheel cylinder, and brake shoes:
Before:
Thomas Duncan
Houston, TX
1971 VW squareback
1966 VW Beetle
Houston, TX
1971 VW squareback
1966 VW Beetle
