65 Corsa by barrist
barrist
Re: 65 Corsa by barrist
Post by barrist »
Well, 2017 is Over...............
Time to make plans for This Year.
Head Start, Wheels and Tires (Christmas)
Next Up, Order time for Brakes and Shocks...............
Have a Great Day,
Bill
http://www.thesamba.com/vw/forum/viewtopic.php?t=482756" onclick="window.open(this.href);return false;
And the New One https://www.corvetteforum.com/forums/c3 ... storm.html
barrist
Post by barrist »
Anyone know of a cure for " The while I'm There " BUG ?
Brakes and Shocks...........that's what I said. :doh:
Then started looking at the Clark's website...........
Well, guess I'll Upgrade to the Dual M/C (and New Lines of course)
New Brake Lines, guess I'll add the Gas Line ( it's right here on the page )
Humm, might as well buy those rear coil springs.
A couple of lifters, ticking. Add a set of those.
Might as well Do the Blower bearing.
Lets see, the insulation kit would Look Good.............
Carpet has a Loooong Cut, might as well.
Those Floor mats would match the new carpet..........
At Least the Wife got the checkbook out of my hand............ :angry:
Now, sit and wait for the UPS Guy. Guess My Spring is Planned........................
Have a Great Day,
Bill
County98
Post by County98 »
Always goes that way. All good projects though!
Cheers!
-Shayne
Lawton, OK
'66 Corsa work in progress
viewtopic.php?f=52&t=8079
barrist
Post by barrist »
Latest Find, (Craig's List)
I Think I've found the solution to the "Time or Money" Problem.......... :doh:
If I find it, and can swing it at the time, I Buy It. I'll worry about installing it when the Lean times roll BACK around.
Can anyone confirm that the Hub extension should be the same color as the column ?
Have a Great Day,
Bill
barrist
Post by barrist »
Starting to work on the steering wheel......
Looks like it was repaired with PLASTER.
Still working, but getting Close.
And, a little Cold today, but got "all" the new shoes On. :cool:
Have a Great Day,
Bill
barrist
Post by barrist »
Well, still to Cold to get much Done.
Started with the Blower Bearing..........Looks like that will Help some of the Leaks.
Bearing in, Clean-up done, too cold to paint.
So start on the insulation, and it's fitting well.
Where is Spring ? :doh:
Have a Great Day,
Bill
Yellow
Post by Yellow »
Many Thanks for all the projects, especially the Top!!
1962 Convertible Monza Powerglide w/ 64 differential and transverse spring and 65 carbs.
barrist
Post by barrist »
A "little" work done on the wheel this week.
And, It Fits. Still have to repaint the column.
Blower bearing Done, waiting for the brass "T" to finish fuel lines. (Guess who bent it reinstalling) :banghead:
Have a Great Day,
Bill
barrist
Post by barrist »
Also got the rear motor mount in.
Started adding the new studs...........
Left Front Done. New drums standing by.
Same for the Left Rear.
I May shorten these studs a bit (3/8 of an inch, I don't want to pop the acorns.
More Later.
Have a Great Day,
Bill
Yellow
Post by Yellow »
barrist wrote:Also got the rear motor mount in.
More Later.
[emoji106]
barrist
Post by barrist »
OK, looks like 3/8" will do it.
Yep, that worked just fine.
And the new drums from Rock Auto, get a squirt of paint. ( I was really surprised, they have the knock-out for brake adjustment ) :tu:
Maybe I'll get a little "garage time" tomorrow.
Have a Great Day,
Bill
barrist
Post by barrist »
A "Little" work getting done.
Top end back together............
One Brake Done, the rear spring clip was replaced after this picture. (Found it Out in the driveway :angry: )
And the New Thermister installed. :tu:
Have a Great Day,
Bill
GasDaddy140
Post by GasDaddy140 »
Wow! You really got it going-on with the great Corvair work! I like it :tu:
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Gregory_Miller
Post by Gregory_Miller »
Is that the Clark's replacement thermistor?
barrist
Post by barrist »
Yes it is, Sorry I had that in another Thread. :doh:
viewtopic.php?f=55&t=14180
Have a Great Day,
Bill
barrist
Post by barrist »
More Brake Updates...................
L/R Done, One at a time, due to Garage Space Constraints. ( Wife doesn't like her car "Out" overnight)
The "plumbers strap" on the muffler will be replaced on the NEXT Clark's Order.
L/F Started..........
And DONE,
Have a Great Day,
Bill
