1965 Corsa Coupe - Want to Verily Codes
Was wondering what the original options were for our '65 Corsa coupe. I had a picture of the body tag and finally spent time figuring most of it out. I think I have it but would appreciate a guru verifying.
Here's the image:
I gleaned the following positions:
01B
ST 65-10767 LOS 1914
TR 713- Y-Y
E 2L 3C
40 5W
From the various resources on this site, I think I have...
1 - Build Date 01B == January second week
2- ST == "Style" and is in next block
3- 65-10737 == 1965 Corsa 2-door sport coupe
4- Los Angeles assembly plant
5- Body number 1914
6- TR == Trim in next block
7- 713- == interior color black on black
8- Y-Y == exterior color yellow upper and lower
9- E 2L 3C == RPO codes: Tinted glass, 4-speed manual, padded dash
10- 40 == 180 HP turbocharged engine
5W == Custom Deluxe Front Seat Belts with Retractors
Here's the image:
01B
TR 713- Y-Y
E 2L 3C
40 5W
5- Body number 1914
Re: 1965 Corsa Coupe - Want to Verily Codes
E. Tinted glass all around
2. L 4 speed
3. C Padded dash
4. O Turbo engine
5. W Deluxe Seat belts ( Chrome Buckles)
Looks right to me except that 40 is group 4 & O is Turbo.
2. L 4 speed
3. C Padded dash
4. O Turbo engine
You did good! Many of us use this page for late model Corvair decoding.
http://www.corvairkid.com/65-67rpocode.htm
What you have for the RPO decodes is correct, just presented slightly different than the decoding pros would do it.
What Jeff is saying is that it is more correct to state that the "O" in group 4 indicates a turbo. Example: Another a similar car might have a Group 4 code such as "4FO" which would still indicted a turbo due to the "O" but the "F" in that series would also indicate the "Comfort and Convenience Package" option.
Group 1 Note: The "1" is never seen on the tag as they wanted to stamp as little as possible to save time. Group 1 always begins with letters (if there was a group 1 option installed).
For your car;
E 2L 3C 4O 5W =
Group (1)
E= Tinted Glass—Windshield and Side Windows
Group 2
L= 4 Speed Manual Transmission
Group 3
C= Padded Dash
Group 4
O= 180 HP turbocharged engine
Group 5
W= Custom Deluxe Front Seat Belts with Retractors
For your car;
E 2L 3C 4O 5W =
Group (1)
Group 2
Group 3
C= Padded Dash
Group 4
Group 5
Here's mine. I've seen where on the forum to get basic info but would appreciate a more detailed explanation if anyone can oblige me...
BODY TAG INFO:
12B
Body Build Date: 12 = December B = Second Week
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. If the letter is an "B" it indicates the second week of the month. (The 1965 model year production cycle would be roughly September 1964 - August 1965).
65-10737 LOS 1201 BODY
Style: 65 = 1965 10737: 1 = Chevrolet, 07 = Corsa, 37 = 2-Door Coupe 4-Passenger,
LOS = Los Angeles (Van Nuys) California, Production Sequence No: 1201
1965 Chevrolet Corvair Corsa 2-Door Coupe - 4 Passenger, Total Production: 20,291
TRim: 713- = BLACK (MONZA 10500 and CORSA 10700 SERIES — Bucket Front Seats)
Paint: Y-Y = YELLOW "Crocus Yellow"
Lucite No. 4620L, Rinshed-Mason No. A1715, Ditzler No. DDL 81500
Example — 1965 Corvair Corsa Coupe in Crocus Yellow
Late Model (1965-66) Turbo Corsa Exhaust Body Cutout
ACC = Accessory line
2LS 3C 4O 5W
1965 Fisher bodytags ACC line. (WRN and LOS)
The Letters are listed in groups. Letters following a number is in that group. The code letters are listed in the order they would appear. Some letters are in more than one group
First Group ( no numeric indicator)
E = RPO A01 Tinted Glass ( Soft Ray glass in all windows)
O = Two tone paint trimpiece (sedans)/ Manual top (pre Jan 65 LA cars only)
D = RPO C06 Power Top
W = RPO A02 Tinted Windshield only
L = folding rear seat (500 series only)
2 = Second Group
M = RPO M35 Powerglide Automatic
L = RPO M20 — 4 Speed Manual Transmission
E = RPO C60 Air Conditioning
P = (LOS cars only) 2 spd Wipers (LOS listed this separately from the CC group)
R = RPO U80 Rear speaker
S = RPO U73 — Rear Antenna
H = Heater delete (code carried over to 66)
3 = Third Group
C = RPO B70 — Padded Dash
A = Rear armrest on 500 sedans
4 = Fourth Group
P = RPO Z01 convenience group ( 2 sp wipers, washers, day/night inside mirror).
O = RPO L87 — Turbocharged Engine
U = Spare tire lock
F = Outside Remote Drivers Mirror/ with CC group
5 = Fifth Group
W = RPO A49 — Deluxe Seat Belts (Chrome Buckles)
O = Seatbelt delete
G = std rear seatbelt
Y = dlx rear seatbelts
This guide will show you how to decode the VIN tag...
I have attached a copy of the 1965 Chevrolet Corvair GM Heritage Center Specs for your model year Corvair.
Thank you all!!!
My body tag, some help needed, here is what I see and think.
12C E
65-10537 WRN 25202 BODY
713- PP
W2L
12C built 3rd week of dec 64
E tinted glass
65-10537 1965, MONZA
WRN assembly plant willow run
713 TRIM COLOR
PP Paint Color ???
W2L ???
12C E
713- PP
W2L
E tinted glass
713 TRIM COLOR
PP Paint Color ???
W2L ???
My Body Tag
BODY TAG INFO:
12C
Body Build Date: 12 = December C = Third Week
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. If the letter is an "C" it indicates the third week of the month. (The 1965 model year production cycle would be roughly September 1964 - August 1965).
Interior paint codes:
E
1965: A= Aqua B= Blue C= Saddle D= Red E= Black F= Fawn H= White/Aqua S= White/Black W= Slate
STyle 65-10537 WRN 25202 BODY
Style: 65 = 1965 10537: 1 = Chevrolet, 05 = Monza, 37 = 2-Door Coupe 4-Passenger,
WRN = Willow Run, Michigan, Production Sequence No: 25202
1965 Chevrolet Corvair Monza 2-Door Coupe - 4 Passenger, Total Production: 88,954
Paint: P-P = ORCHID "Evening Orchid Poly."
Lucite No. 4632L, Rinshed-Mason No. A1722, Ditzler No. DDL 50693
Example — 1965 Corvair Monza Coupe in Evening Orchid
W2L
2 = Second Group
L = RPO M20 — 4 Speed Manual Transmission[/size][/b]
3 = Third Group
NONE
4 = Fourth Group
NONE
5 = Fifth Group
NONE
