Sending Unit
Sending Unit
Is there anyone in the London ON area who may have a sending unit for me? Mine works but is leaking from the supply line. 65 Monza.
Re: Sending Unit
I'm assuming you are talking about the fuel tank fuel gauge sending unit? Is the unit leaking from the round seal area, the outlet tube, the rubber fuel line, or ???
You might have to turn to Clark's Corvair Parts or possibly the Corvair Ranch to obtain replacement parts...
http://www.corvair.com/user-cgi/catalog ... IN&page=69
Part number C847: 65-69 STAINLESS GAS TANK SENDER UNIT ** GKT-C155,RETAINER-C156,STRAINER-C261*
Weight: 1 lbs 0 oz
Catalog Pages(s): 69(2)
Price: $ 54.85
http://www.corvairranch.com/
1079 Bon-Ox Road
Gettysburg, PA. 17325 USA
phone # 717-624-2805
corvairranch@embarqmail.com
I have attached extracts from the 1965 Corvair Assembly Manual and the 1965 Corvair Chassis Shop Manual for your reference.
Weight: 1 lbs 0 oz
Price: $ 54.85
1079 Bon-Ox Road
- 1965 Corvair Assembly Manual - FUEL TANK.pdf
- (1.19 MiB) Downloaded 13 times
- 1965 Corvair Chassis Shop Manual - SECTION 8 - FUEL TANK AND EXHAUST SYSTEM.pdf
- (1.65 MiB) Downloaded 8 times
Re: Sending Unit
I got mine to work. It was leaking on the supply tube on the outside. I used JB Weld and ran neoprene right up to the plate. No Leaks. My Gas gauge even works now...get this... the sending unit was fine. The float had a hole in it so gas got in and it didn't float. Replaced float ball and voila.
