Actually, 1960-1962 Corvairs don't have a PCV system -- just a Road Draft tube extending from the crankcase top cover through the bottom sheet metal cover on the right side.flat6_musik wrote:When you say "new PCV valve too"......you know these cars don't actually have a PCV valve, it's just a pinhole orifice in that metal breather tube. You don't actually have a PCV valve on this car (like from a regular engine) right? If it were my car, I would also start by plugging every single vacuum port (even the crossover) and go from there.scottydont wrote:I know it's just as it should be (new pcv valve too, and I've double checked to make sure the orientation is correct), but the best idle I've had so far was with the crankcase vent to the air cleaner plugged. To me that says its too lean at idle since it's under slight vacuum from the pcv.... but the other tests I did dont back that up.... I have to be getting something wrong... Just don't know what at this point.
Left-click on each image with your mouse to enlarge the picture for better viewing... In 1963, a closed Positive Crankcase Ventilation system was introduced using a tube connecting from the crankcase top cover to both the right air cleaner and to the vacuum balance tube, regulated by a PCV valve. In 1964, the PCV valve and dual air cleaner assemblies were replaced by a single, center mounted air cleaner housing and a PCV tube that utilized a fixed metered orifice in place of the original PCV valve introduced in 1963. HOWEVER, engines with limited clearance above the engine, as in FC vehicles and passenger cars with an Air Conditioner system mounted above the engine retained the low-profile dual air cleaners coupled to a PCV system that continued to utilize a PCV Valve.
