Looks awesome!
Ira
BMW uses a 120mm on 5 pattern, while the LM Corvair uses a 120.65mm (4.75") on 5 pattern. They are very close, but not exactly the same. I have used this pattern before without any issues as long as the hub center fits correctly and you use a cross pattern when tightening them.chanceparker wrote:I thought BMW wheels had a slightly different bolt pattern. Did they bolt right on?
flat6_musik wrote:I know these aren't super impressive, but they'll do for now. They're 15X6~15X7 chrome reverse wheels from Summit Racing. They were fairly cheap and I couldn't handle the stock 13's anymore. Oh and I've kinda been on a "Two-lane Blacktop" trip with that Harrison Ford '55 Chevy look. I like them, they don't rub and I'm happy with them for now. I might even put some little Corvair dog dish hubcaps on them later. Or I might even get some wider ones later.....who knows?
I love this look....
Hey Grymm.....that's cool! Just FYI, I'm not positive if that center area is the absolutely correct size to pop a small Corvair dog dish hubcap onto. It may be a little too big, I'm really not sure. I don't have a dog dish hubcap handy to check either. But anyway, yeah.....here's the link to the wheels from Summit. They're called Wheel Vintiques 64 series for $118.95 each. To tell ya the truth, I've got a feeling that that center area is sized from an old Ford wheel. I could be wrong.Grymm wrote:If I remember correctly the same car that was first in "Two Lane Blacktop" (in primer with a home made hood scoop) was prettied up and painted and then appeared in "American Graffiti" with Harrison Ford at the wheel =)
Not sure if you knew your two '55 Chevy references from two different movies were the same car!
I like your wheels a lot, and I think putting the little Corvair hubcaps in the center is a fantastic idea.. I might get a set of those wheels and do it myself in the future now that you sparked the thought =).
