Yenko Stinger Stage II upgrades
- NewCorvairFan
From what I understand, stage II Stingers were all ordered with a 140 and the main upgrades to the engine are better carbs and a better cam. Does anyone know the specs of these parts and if they can be bought from aftermarket sources?
1967 Monza Convertible 4 speed
1982 Cadillac Eldorado Touring
Re: Yenko Stinger Stage II upgrades
The Stage II 175 bhp, had everything the Stage I had plus the following;
Stinger High Performance camshaft kit, (includes heavy duty valve springs and retainers.
Special reworked cooling fan.
High compression cylinder heads, (10-1 compression).
Modified carbs for hard cornering.
High-capacity ignition secondary wiring.
lightened and bolted flywheel.
Level control horizontal oil pan baffle.
Main bearing select fit.
Select fit piston skirt clearances for high performance.
I do not know the specs of the cam but someone does, I'm sure.
Ken Hand
248 613 8586
vairmech@aol.com
Corsa Past President
Corvanatics Prez
Ultravan Club Prez
Chair 2007 Detroit Convention
248 613 8586
vairmech@aol.com
Corvanatics Prez
Ultravan Club Prez
