I was thinking about it. It might look a bit more like the Spyder outlet. Ill have to see how I have to route it on final fitment.
Building a modded FI 140 for my Wagon
- toms73novass
Re: Building a modded FI 140 for my Wagon
1962 700 Wagon
1963 Spyder convertable
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
- MtnVairMike
Thanks so much Tom for the added details!toms73novass wrote: ↑Sat Apr 06, 2024 8:39 am Mike here are some more pics of the mount with out the pressure plate adapter in place. The adapter bolts to where the flywheel would mount.
Also the combo (minus clutch friction) for final balancing. Sometimes you get lucky and can "clock" the pressure plate and flywheel to get balance or close and then adjust a minor amount for final assembly balance.
The center hub is turned to fit the bore of the flywheel, a plate to bolt the flywheel to is bolted to the hub and the whole thing sits on the shaft.
Mike
- toms73novass
Your welcome Mike.
1962 700 Wagon
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
- toms73novass
So the 20min breakin went well, just a weap on the oil filter bolt that I think is fixed now.
I used the method that Mike Levine uses by overfilling by 2 quarts so the cam is bathed in oil during breakin. Also, use the cam/lifter lube. Always paranoid to get a flattened lobe.
Next is to drop the drivetrain and swap the efi over to the new engine.
1962 700 Wagon
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
- toms73novass
Swapped out the engines and working on fitting up the exhaust to exit in the stock location. I am using a stock turbo muffler but flipped so biased to drivers side instead of passenger like on my spyder. I had to make a new muffler hanger outer bracket to position it in the opening.
Waiting on vband to finish up welding on the muffler.
1962 700 Wagon
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
That is going to be a stealthy look on the exhaust. Looking forward to a sound clip!
Sam Russell
1962 Monza Wagon
1964 Monza Spyder
1962 Monza Wagon
1964 Monza Spyder
- toms73novass
I am hoping it has a bit of a lope at idle to it since it has the OTTO20 and the turbo muffler and no drone at rpm.
1962 700 Wagon
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
Looking great. I am curious to hear the sound clip as well!
Keitho64
05 GTO
00 911 C2
64 Corvair Monza
05 GTO
00 911 C2
64 Corvair Monza
I had a stock 140 in my 64 Spyder and made a big single crossover to a stock turbo muffler. It had great sound.
Sam Russell
1962 Monza Wagon
1964 Monza Spyder
1962 Monza Wagon
1964 Monza Spyder
- toms73novass
The engine has a nice throaty sound at WOT and rumble at idle (The base is a bit cut down in the video). Cruising it competes with the Nash fan Woosh! No drone.
Video link https://www.amazon.com/photos/shared/hj ... 6_cGv34eM0
1962 700 Wagon
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
Sounds nice, but not as nice as the car, and I'm only seeing the back end. Looks fantastic!
- toms73novass
Car pic.
1962 700 Wagon
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
Beautiful car Tom, makes me want a wagon.
