Pressure Plate/Flywheel
Having trouble finding that special part you need? Post a wanted ad.
Alexh_2023
Post by Alexh_2023 »
Need a new (Or cut) flywheel, clutch, and pressure plate, could use recommendations or best dealers to get from
Lane66Monza
Re: Pressure Plate/Flywheel
Post by Lane66Monza »
Get with ken Hand on this forum. Good prices. He will balance pressure plate and flywheel if asked, for a reasonable fee.
Al Lane
Southeast Georgia
1966 Coupe 110 4 spd
Alexh_2023 wrote: Wed Apr 30, 2025 4:53 pm Need a new (Or cut) flywheel, clutch, and pressure plate, could use recommendations or best dealers to get from
Engine size determines first or second generation type as does turbo and 140HP that are also different. MIx the wrong parts and you will have a poorly working clutch.
Alexh_2023
This engine is kind of a mis match, it's primarily a 140hp parts motor, just has the original 64 casing, everything else I believe is 65 140hp parts
texas yenko dude 199
Post by texas yenko dude 199 »
Being it is basically a stock 140, I would suggest the correct weighted pressure plate. The flywheel could be lightened. If it was a performance 140, then the non weighted pressure plate will spin up fater in the mid and top end. The weighted pressure plate will help you come off the line with some added stored up energy.
Alexh_2023 wrote: Wed Apr 30, 2025 9:04 pm This engine is kind of a mis match, it's primarily a 140hp parts motor, just has the original 64 casing, everything else I believe is 65 140hp parts
If it is bolted to a 64-69 bellhousing and transmission then as Ken said for daily driving the original 140 HP pressure plate and stepped flywheel will work fine. Over the years issues have come up with "mixing and matching" parts as they did change. Here is a good article from the Corsa West club about what works and how to identify parts. See .pdf article.
First vs Second Design Clutch REV 2..pdf
(1017.68 KiB) Downloaded 9 times
Return to “Parts Wanted”
