Pulling a Corvair onto a flatbed tow truck
- tricordati
Any recommendations on pulling a Corvair onto a flatbed tow truck either from the front or rear preferred?
Re: Pulling a Corvair onto a flatbed tow truck
When I transported my 61 on a tilt bed I went ass first. It rode fine. Getting the weight close to the CG of the truck is key.
First corvair in 1985
Have owned 4 corvairs since
65 Corsa coupe 180 turbo
66 Monza coupe 110 PG
66 Monza coupe 140 PG
Anchorage,AK
Anchorage,AK
- tricordati
Thanks. I have a 63 and was also wonder where the tilt bed operator hooks on to at the rear.
Is your car not currently running? I just backed my car on.
The guy can make a bridle with his cains and winch it on if it's not running.
There may be other opinions but I had the driver chain to the crossmembers for transport. I followed behind the driver and the car rode great.
Anchorage,AK
Anchorage,AK
- tricordati
Thanks. Not currently running so need to transport it.
I am looking for advice.
Tomorrow I have to retrieve my ‘65 from the seller and will be using an electric winch to pull it up rear end first onto my trailer.
At this point don’t know if it will roll or not, have a set of tires to go onto it to replace the ones that won’t inflate.
I already did a search, I’m lousy at searching forums and came up with zilch.
My problem is that I am really unsure where to hook the chains to so to pull it up onto the trailer.
Someone on another site mentioned the rear engine mount but I’m not sure that’s a good place at all.
There are oval holes in the body in the bottom of the rockers that are made for T hooks. You could use nylon straps around the outside ends of the lower links in the rear suspension too. The engine mount is not the place to connect and you would have to partially disassemble the car to get at it anyway. Do not use the bumper mounts! They are way too flimsy.
Ok thanks for the fast reply, I should have straps in my tow box (former box truck) and I’ll look for the slots for the t-hooks when i get there. The links may be the best bet right now.
Just a follow up, Joel I used a strap around the lower arms, should have taken a picture of it but didn’t have time, there was no problem with getting the car on the trailer, pulled it up with two flat tires because I could not get the old ones off the car.
It came up with little fanfare and looks happy at its new home. Next week it will be moved into its new spot for a bit and wrapped up for a while.
I learned the winch has too much cable and I have to replace it with something smaller and less of it. I don’t need a 20k cable.
Also learned that my trailer (new to me) pulls really well, better than my old one.
Excellent!
It is great when you get one all loaded and it pulls nice too.
How can a winch have too much cable unless it won't all fit the spool?
20k must be a really big cable 5/8?
Well I was wrong, i thought it was 7/16 inch but it is 1/2 inch cable, 80 feet of it which is a pain to deal with on the spool because I can’t layer it right.joelsplace wrote: ↑Fri May 21, 2021 8:16 pm Excellent!
Break limit I thought for 7/16 was 20k?
My other winch has 3/8 inch cable and layers great.
A half inch cable would need a larger diameter spool than a 3/8 to wind correctly unless the strands on the 1/2 were small enough. My 8k winch has broken 3/8 cable before but I'm sure it was probably damaged.
7/16 can be 20k depending on what kind.
I have to use a snatch block and come along to keep mine winding correctly. I bought level winders but haven't installed them yet.
