What's that small hole in my 66 Trim tag???!!!
Paul Winvoices
Re: What's that small hole in my 66 Trim tag???!!!
You do realize that these service bulletins are posted on CORSA's website
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
I guess I've been around these dang Corvairs too long because I knew it was to indicate a vehicle that had the shoulder harness mounting points installed under the headliner.
- MtnVairMike
I have seen several 66 convertibles with the hole punched.
1966 Corsa turbo
- MtnVairMike
I have two '66 convertibles with the 3/16 hole punched. No shoulder harnesses here. On the post by "notched", the hole looks quite a bit bigger than 3/16".
- IMG_1004.JPG (29.48 KiB) Viewed 857 times
The hole sizes aren't' always 3/16". I pictures of coupe tags with the larger hole size.corvairsince70 wrote: ↑Mon Apr 09, 2018 4:56 am I have two '66 convertibles with the 3/16 hole punched. No shoulder harnesses here. On the post by "notched", the hole looks quite a bit bigger than 3/16".
1966 Corsa turbo
