Bucket Seat Replacement
I looking to replace the bucket seats in my 1965 Corsa convertible. Would like to get a set of later model buckets with the headrests or highbacks hopefully in red. Second choice would be an aftermarket suggestion that would fit the '65 with as little replacing items as possible. Any suggestions of thoughts will be greatly appreciated.
Thanks
Thanks
Re: Bucket Seat Replacement
There are many possible choices all depends on what you like. ALL except original Corvair seats will require modification to the seats or the cars floor to mount properly (evenly and safely). The amount difficulty of mounting will or course vary with the seat chosen.
- GasDaddy140
There are a zillion Mazda Miatas out in the world with a wide variety of colored bucket seats. Check your local wrecking yard or eBay. I put Miata bucket seats in a 1970 Datsun 2000 Roadster and they were great.
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
Corbeau bucket seats will fit and they even make sliders for late model corvairs although I had to drill the holes out in the brackets I got because they were not aligned with the factory mounting points perfectly. Still, no hacking or modifying of stock sliders or the floor.
Nate Wolfe
65 Corsa 180
61 Lakewood 140
65 Corsa 180
61 Lakewood 140
Hello All,
I'm looking for bucket seats that have integral shoulder belts mounted as part of the seat. I want the shoulder belts in front due to safety stats.
I've seen some wrap around type seats that have this shoulder belt feature, but didn't get info on them.
Anyone seen this type of shoulder belt set up?
I've done some looking into this myself for my LM convertible. There are a number of complications- floor reinforcement is required, many seats are much heavier than stick, have complex external electronics, and need to fold forward for access to the back seat. That pretty much reduces you down to some late model convertibles:65Monza140 wrote: ↑Thu Jan 25, 2024 8:33 pm I'm looking for bucket seats that have integral shoulder belts mounted as part of the seat.
Saab 93
BMW 3 series
Chrysler Sebring
If you don't need to fold forward, you have a few more choices like some 2 seat convertibles and a few trucks like a couple years of the chevy trailblazer and many years of the GM full size trucks. But, those seats tend to be more bench-like and less bucket-like.
In the end, I think I will forgo the integrated belts, and add them to the door opening instead. That opens more options for seats and will be lower weight overall.
allan
1965 Monza vert
Central VA
Central VA
- scooperman
My interior preference is an older look, like something you would find back in the day. My old race car has a 60s bucket race seat, I would not want that in a daily driver. My Vair is not air conditioned and I live in Florida, so although I like the leatherish look and feel I probably should get vented or cloth insert seats.
I go to car shows/events and steal interesting ideas for my eventual Vair rebuild. I saw a nice 66 Nova with seats that looked comfy and not out of place, asked the owner if they were custom made. No, they were Procar seats from Speedway Motors, and he said he liked everything about them, no problems. I poked around on the Speedway site and found this seat also available with a hounds tooth insert. I have not purchased seats yet, I might go with these.
- toms73novass
I have the Procar wiyh out headrest in my Wagon and are very comfortable. The only issue would be with a 2 door they do not fold forward.
1962 700 Wagon
1963 Spyder convertable
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
I too was looking at the local LKQ yard for a nice set of buckets for my LM convertible. I found that most later model cars have air bags built into the seats. I didn't like the idea of having a non-functional airbag on my shoulder. It might accidentally "function".
I went with Procar seats. I then had them upholstered in red Clark’s matching vinyl (I didn’t replace the back seat). I think they turned out pretty well.
Rod
1964 110 Monza Convertible
1966 140 Corsa
1966 140 Corsa
I've used Honda Civic seats (pre airbag) in two of my cars. They are comfortable adjustable and tilt forward for rear seat entry.
I might also add that there is a substantial weight savings eliminating the Corvair seats. I have been a stock guy most years, but lately I've realized a lot of advantages with replacing my seating for something newer.
