Corsa dash lenses
skipvair
Corsa dash lenses
Post by skipvair »
Does anyone repro new lenses for the corsa dash? Mine are cracked. Cant find on Clarks site.
Frank Metasavage
66 Corsa 140 4 speed Stock
SteveH
Re: Corsa dash lenses
Post by SteveH »
check the clarks used stuff, I bought a set there a couple months ago
$23 for the whole set of 4 ($6, $6, $6, $5)
http://www.corvair.com/user-cgi/catalog ... ge=USED-47
CORSA Member #034095
skipvair
Post by skipvair »
Thank you. Didn't think about used stuff
Frank Metasavage
No new ones, but plenty of good used lens around. I've gotten some from Clark's. Don't expect them to be perfect, but if they are not cracked any scratches can be easily removed with a headlamp lens polishing kit. Use the small kit, no power tools used, from Turtle Wax. Works great, but be careful with the numbers on the back of the lens. Don't skip the sanding steps - start with course pad and work to finer, then polishing fluid. They will come out looking like new and will be clear.
See https://www.turtlewax.com/our-products/ ... storer-kit
Available at auto parts stores and on Amazon.
skipvair
Post by skipvair »
Got one at home
Frank Metasavage
