Oil cooler circulation
wqqdster
Post by wqqdster »
I have been trying but have been unable to find a circulation schematic which shows the oil cooler. I'm trying to put my temp sender at the exit of the cooler but I don't know which one (top or bottom) is the hot oil and which is the cooled.
A follow up question.... is the filter on the hot side or cool side of the filter? My present sender is at the filter.
As usual, thanks in advance,
Gary O
cnicol
Re: Oil cooler circulation
Post by cnicol »
It takes a little head scratching to figure out the drawing but you will find info on page 6-12 in the ''65 manual.
Steve62
Location: Altadena, California (Just north of Pasadena)
Post by Steve62 »
Cool oil exits the top of the cooler. Hope this helps...
Corvair Lubrication System
Could be better, could be worse...could be riding in a hearse!
wqqdster wrote: A follow up question.... is the filter on the hot side or cool side of the filter? My present sender is at the filter.
OIl gets filtered before it goes to the cooler.
wqqdster
Post by wqqdster »
cnicol, I have an old Clymers and a Motor's manuals but neither had the circulation.
Steve62, yes absolutely that helps! Now I know where to put my sender.
Thanks azdave.... I have the temp sender right at the filter housing so I'm measuring it at its hottest.
Thank you all!!
Gary O
