top cover torque specs and sequence
72BBNova
Post by 72BBNova »
I'm changing my top cover to a LM bigger bearing, what are the torque specs for the bolts and is there a sequence. I can't find my manuals to look it up. Thanks Jeff
Jeff
1964 Spyder coupe
1966 Corsa convertible (project, some assembly required)
1972 Nova 496/6spd
1975 Chevy Cheyenne 454 C20 camper special
Re: top cover torque specs and sequence
The torque spec for the crankcase cover 5/16-18 bolts is 7-13 ft. lbs. in both the 1961 and 1965 shop manuals. No sequence is specified. Anti-seize compound is recommended.
If you ever need to download extra copies of the Corvair shop manuals, supplements, or other technical documents, you can find them here...
Having the proper reference materials – including the factory shop manual – is important. You can download all of these references at no cost onto your computer in Adobe Reader format from the links below. You can then read through the procedures and print the appropriate pages that you will need to refer to as you go through the procedure on your Corvair. Of course, you can also purchase hard copies of the shop manual from Clark's Corvair Parts or other sources. I hope you will find some useful references at these websites to add to your personal technical library.
Free Downloadable Corvair Shop Manuals, Parts Manuals, Service Manuals, etc.
Corvair Tech Pages Index
:link: http://1969corvair.com/techpages/Corvai ... Index.html
Free Early Model Corvair Shop Manual & Other Useful Manuals
:link: http://www.corvair.org/chapters/corvanatics/manuals.php
Adobe Reader - Free Utility for viewing files in Adobe Reader (.pdf) format...
If you don't have this free application installed on your PC, you can download it here:
:link: http://get.adobe.com/reader/
72BBNova
Post by 72BBNova »
Thanks Brad your the best. I've been working on this thing all winter and just keep running into small road blocks along the way. I'm hoping to get it going so I can drive it to Knoxville in June. Thanks again Jeff.
Jeff
1964 Spyder coupe
1972 Nova 496/6spd
