pushrod removal tool
i bought a pushrod removal tool from clarks but it has no instructions of any kind and just looking at i have no clue how to use the thing. i guess i could call clarks but im guessing several of you can enlighten me. thx for the help
- Fast Eddie
- Corvair of the Year
Re: pushrod removal tool
The way we used to remove pushrod tubes was to use channel lock pliers. Place a rag in the jaws and just squeeze enough so it wont slip, not tight enough to dent the tube. Tap the pliers gently. Once the tube comes out, remove the O ring And slide it the rest of the way out.
- Fast Eddie
I forgot to mention twisting also helps.
I've never seen the Clark's tool so I can't comment. Pics?
Some people have slit an old spare pushrod tube and use it on the back side of the outer tube area to push the stuck tube through the head.
A few pics posted here.
http://corvaircenter.com/phorum/read.ph ... 464,324790
I pulled these illustrations from some earlier Corvair Forum posts...
Clark's sells these push rod tube removal tools...
http://www.corvair.com/user-cgi/catalog ... ge=TOOLS-3
Part number C1439: PUSH ROD TUBE REMOVER TOOL !!!NOTE- MANIFOLDS DO NOT NEED TO BE REMOVED
Weight: 1 lbs 0 oz
Catalog Pages(s): T-3
Price: $ 49.00
Weight: 1 lbs 0 oz
Price: $ 49.00
Might be a dumb question but is this for when the head is still connected?!? Mine fell right out when I took the head off........
Scott Farnell
Calgary, Alberta
65 Monza (Corsa Clone)
Calgary, Alberta
Yes. Place tool on the tube so you can tap on the tool to push the tube out towards the outside.
Ok. Couldn't be clearer then their catalog illustration. See the hammer head with either tool type?
- davemotohead
The pic brad posted of the Blue tool is mine I got from Dave Palmer who make's them,you slide the tool up like the picture and take a hammer handle and put it between the block and the arm on the tool and push slightly and the push rod tube pops right out! I use it every time I remove push rods and its a GREAT tool for Corvairs, Sorry Eddie But channel locks or vice grips should not be used! I have tossed so many bent tubes from people who did the channel lock method! Buy corventureDaves Tool!!
- Racemaster
I used an old push rod tube to make a removal tool. It's a quick easy way to remove the tubes without bending then and it was FREE!
61 & 63 Corvair Rampsides
65, 67, 69, 70 Mustang fastbacks
72 Duster 440 alky bracket car
70 Mustang Mach1 tube chassis car 514ci
61 & 63 Corvair vans
various others.......
Mid Tennessee
Mid Tennessee
thx guys, i knew i could count on you. i get it now. didnt realize pushrod tube comes out through head. it all makes sense. thx again for the help. my car is a 65 fourdoor with 48k original miles. runs great but needs oil leaks fixed. appreciate the help. tom
