What happens if....?
...you turn this nut?
I was digging through the shop manual and came across the item below...
I am to curious.
I'm thinking that if you turn the nut the car will teleport directly to Ralph's front yard....maybe...could happen.
What do you think?
Oh and happy 4th!
I am to curious.
What do you think?
Oh and happy 4th!
No stock parts were harmed during the on going restoration of this Corvair....ok, maybe a little bit.
1965 Corsa Coupe #5065
Re: What happens if....?
Dude.......I am sooooo gointa' turn that nut!!!!! Don't tell me what to do, man!!!
Mike S.
65 Corsa 140 Ragtop
CORSA member
65 Corsa 140 Ragtop
CORSA member
- davemotohead
I turned that nut Once! only once!
SHHHH!! That's the secret nut to engage the Infinite Improbability Drive...
1949 Ford 8N Tractor
Is that the same as "Don't press the red button"?
I just went outside and turned that nut. Does the regulator still have to be on the car to see the results?
that's the same nut (but,painted black) that H Clinton gave to the Russian to reset...if you turn that button,you automatically become a russian subject......
