GM disc brake conversion
I have heard you can use spindles from a GM G body from the mid eighties on a corvair front suspension for a disc brake conversion, i know you have to do some modification to the spindle to get it to work, i was wondering if anybody has done this and could let me know all the ins and outs
Drive it like you stole it
65 Turbo Monza Coupe
64 monza convertible 4 spd
Grand Ledge, Michigan
Re: GM disc brake conversion
Did this to my LM. Check out this topic and there is pictures of stock top ball joint with spindle machined at top ball joint to fit corvair.
The lower I found it easier to install the factory ball joint for the spindle Ur using and modify the corvair a arm to take that viewtopic.php?f=52&t=7122
65 disk brake and drop kit
