Cooling,
Initially i was looking at removal of the factory fan and adding an electric fan. I figured just as with any belt fed fan that you can free up some horespower absorbed by accessory draw. So far i am reading that this is a big fat no-no. What makes the least amount of sense to me is that the factory fan actually hinders cooling at higher speeds? Something about being too close to the engine and restricting the natural flow of the air passing under the car. What about the use of a high powered electric fan that can be turned off after a certain speed to help with cooling in both low and high speed instances? Also i was looking into adding larger oil and trans coolers that are either cooled with small electric fans or the addition of small scoops somewhere that will direct more air into the engine bay and placing the coolers directly in front of them.
Turbo,
So i know that orient express and a couple other manufacturors use very small turbos to power drag bikes. running those low on the car off of the manifolds, up into a WRX top mount intercooler, then split into the carbs. The WRX intercooler has a built in BOV. I know it would need so good tuning as well. What would be used to regulate the PSI going in at around 8-9lbs and what supporting mods would be needed. This is a 63 twin carb 164 motor. I read that the engine already has low compression so would a thicker head gasket be necessary?
http://www.ecotrons.com/products/small_ ... bocharger/" onclick="window.open(this.href);return false;
Excuse my horrible artistry.
![Image](http://i28.photobucket.com/albums/c245/boostnsrt/IMG_20140402_164650_470_zpsofiizirr.jpg)
Someone help straighten me out.
