Clutch Install
- 65corvaircopnj
Clutch Install
I'm getting a knowledgable old car mechanic to install a new clutch, flywheel, and pressure plate. Any idea how many billable hours it should take? Thanks!
Chris
55 Belair Sedan
Used to have: 65 Monza Convertible; 66 Monza Cp w A/C ; 63 Monza Cp
55 Belair Sedan
Re: Clutch Install
First question is whether this mechanic is experienced with Corvairs. The reason is, this job requires the entire drive train to be removed from the car. (As a side note here, if he says he can remove the engine without pulling the transmission, find someone else!)
years ago, I knew a guy in my club who claimed he could do one in an evening after work. I remember in my younger days, I could pull my '64 into the basement, and have the drivetrain sitting on the ground 30 minutes later. That included time to jack the car up, one corner at a time, and put it on jack stands. Don't think I could do that now, been too long.
Point is, removing the drivetrain is not that bad, but you have to know what to disconnect, that is the time killer. If you have to figure out what to do and how to do it, how to fit the jack, etc it can take much longer. The rubber engine seals and heater hoses alone can be trying at times.
Plus, it is far too easy to put the new clutch plate in backwards. Do that, and you have to start all over again.
Hope this helps!
Hope this helps!
Phil
64 Spyder convertible
Re: Clutch Install
Here are some comments I wrote earlier regarding a clutch replacement job...
There are several options for replacing the flywheel, as depicted below. I have not had to replace a flywheel since 1980, and many of these options were not available back then, so I cannot personally recommend one method over another. Perhaps other Corvair Forum members can advise you on this. But I would recommend reading over all of the clutch section of the Clark's online catalog to familiarize yourself with flywheel, pressure plate, and clutch disc options. When you pull the powertrain and separate the transaxle from the engine. You will want to replace anything that appears worn, considering the condition of the pilot bushing, throwout bearing, pressure plate and clutch disc, crankshaft seal and input shaft seal. The throwout bearing shaft that protrudes from the differential should also be carefully examined for cracks or pieces that have been broken off (a common problem). Damage to this part can occur when you separate the transaxle from the engine, if the input shaft sticks in the clutch assembly and the other end of the two-foot splined shaft pulls free from the transmission. If the alignment of the transaxle and engine is not maintained while separating the two components, the input shaft can act like a lever and place lateral or downward pressure on the throwout bearing shaft – sometimes cracking or breaking it. Replacing that part requires dismantling the differential. Also, the input shaft seal should always be replaced, and the crankshaft seal should be examined for signs of oil leakage. In other words, going through the process of pulling the powertrain to replace a flywheel warrants a complete clutch assembly inspection and overhaul. You don't want to reassemble the powertrain with any worn or faulty clutch components, or you could have to repeat the procedure again to fix something you missed the first time!
http://www.corvair.com/user-cgi/catalog ... N&page=109
http://www.corvair.com/user-cgi/catalog ... N&page=110
http://www.corvair.com/user-cgi/catalog ... N&page=111
http://www.corvair.com/user-cgi/catalog ... N&page=124
A spare clutch cable in the trunk is also not a bad idea. These can break and leave you stranded. A spare in the trunk as a part of your spares kit gives you a roadside repair option that can get you back on the road without having to wait for a parts shipment to replace this potential "show stopper".
http://www.corvair.com/user-cgi/catalog ... N&page=112
- cvair4life
Re: Clutch Install
Assuming no complications and assuming that by "old car mechanic" you have somebody familiar with the way things used to be... and assuming he has a shop to work in.... My personal estimate would be to see no more than 8 hours of billed time.65corvaircopnj wrote:I'm getting a knowledgable old car mechanic to install a new clutch, flywheel, and pressure plate. Any idea how many billable hours it should take? Thanks!
I did 2 clutch plate swaps at a tech day with the help of a friend of mine in about 8 hours (just the two of us). That was bare bones tools in one of the guys backyard concrete patios and no lift (just floor jack and stands). Granted we had done a couple before and this wasn't something new and there were no complications (wild huh...) and there were two of us working together....
Long story short - billable hours should be 6-8 hours total.
1966 Corsa Coupe
- cvair4life
Re: Clutch Install
Swngaxl wrote:First question is whether this mechanic is experienced with Corvairs. The reason is, this job requires the entire drive train to be removed from the car. (As a side note here, if he says he can remove the engine without pulling the transmission, find someone else!)
But to that end - you don't have to remove anything but the engine (and it's comrades) to swap the clutch assembly out.
1966 Corsa Coupe
Re: Clutch Install
Once you have pulled the axles and disconnected the throttle, clutch and shift linkage (and unplugged the backup light switch), dropping the entire powertrain in an EM Corvair requires removal of one nut in the rear and two nuts in the front. (I'm not listing the steps for disconnecting the engine components around the perimeter of the engine, which would have to be disconnected either way, with removal of the engine only or the entire powertrain).
Personally, I prefer removing the entire powertrain when doing a clutch job, removing the cylinder heads, or any other major job. It is easier having the powertrain out in the open when working on it than it is trying to do all that work while lying on your back under the car.
The attached reference, Corvair and Corvair 95 Power Train Removal & Installation, outlines the procedure.
- Corvair and Corvair 95 Power Train Removal & Installation.pdf
- (3.35 MiB) Downloaded 168 times
- 65corvaircopnj
Re: Clutch Install
Thanks for the input everyone. I have removed the drivetrain twice before in my garage. The second time due to breaking the 'nose cone' on the diff. I was trying to cut corners by removing only the engine as a whole new suspension, 4spd, and rear were getting swapped in. Lesson learned that I should have mated the whole drivetrain the first time prior to installing!
I gave my mechanic the shop manual so he has a better idea what he's being asked to do and , yes he is one of those guys who 'remembers working on them when they were fairly new'. Thanks for the input guys, just didn't want to shell out 1.5 - 2 x what I should for his inexperience!
Chris
55 Belair Sedan
55 Belair Sedan
