Page 3 of 8
Re: 65 Corsa by barrist
Posted: Mon Jan 15, 2018 1:25 pm
by barrist
Well, 2017 is Over...............
Time to make plans for This Year.
Head Start, Wheels and Tires (Christmas)
Next Up, Order time for Brakes and Shocks...............
Posted: Wed Jan 31, 2018 6:11 am
by barrist
Anyone know of a cure for " The while I'm There " BUG ?
Brakes and Shocks...........that's what I said.
Then started looking at the Clark's website...........
Well, guess I'll Upgrade to the Dual M/C (and New Lines of course)
New Brake Lines, guess I'll add the Gas Line ( it's right here on the page )
Humm, might as well buy those rear coil springs.
A couple of lifters, ticking. Add a set of those.
Might as well Do the Blower bearing.
Lets see, the insulation kit would Look Good.............
Carpet has a Loooong Cut, might as well.
Those Floor mats would match the new carpet..........
At Least the Wife got the checkbook out of my hand............
Now, sit and wait for the UPS Guy. Guess My Spring is Planned........................
Posted: Sat Feb 24, 2018 9:43 am
by County98
Always goes that way. All good projects though!
Posted: Mon Mar 05, 2018 2:08 pm
by barrist
Latest Find, (Craig's List)
I Think I've found the solution to the "Time or Money" Problem..........
- corvairsteeringwheel9.jpg (6.23 KiB) Viewed 3539 times
If I find it, and can swing it at the time, I Buy It. I'll worry about installing it when the Lean times roll BACK around.
Can anyone confirm that the Hub extension should be the same color as the column ?
Posted: Wed Mar 21, 2018 9:53 pm
by barrist
Starting to work on the steering wheel......
Looks like it was repaired with PLASTER.
Still working, but getting Close.
And, a little Cold today, but got "all" the new shoes On.
Posted: Sun Apr 01, 2018 8:26 pm
by barrist
Well, still to Cold to get much Done.
Started with the Blower Bearing..........Looks like that will Help some of the Leaks.
Bearing in, Clean-up done, too cold to paint.
So start on the insulation, and it's fitting well.
Where is Spring ?
Posted: Sat Apr 28, 2018 8:02 am
by Yellow
Many Thanks for all the projects, especially the Top!!
Posted: Sat Apr 28, 2018 6:44 pm
by barrist
A "little" work done on the wheel this week.
And, It Fits. Still have to repaint the column.
Blower bearing Done, waiting for the brass "T" to finish fuel lines. (Guess who bent it reinstalling)
Posted: Sat Apr 28, 2018 6:53 pm
by barrist
Also got the rear motor mount in.
Started adding the new studs...........
Left Front Done. New drums standing by.
Same for the Left Rear.
I May shorten these studs a bit (3/8 of an inch, I don't want to pop the acorns.
More Later.
Posted: Mon Apr 30, 2018 8:33 pm
by Yellow
barrist wrote:Also got the rear motor mount in.
More Later.
[emoji106]
Sent from my [device_name] using
Corvair Forum mobile app
Posted: Sat May 05, 2018 6:49 pm
by barrist
OK, looks like 3/8" will do it.
Yep, that worked just fine.
And the new drums from Rock Auto, get a squirt of paint. ( I was really surprised, they have the knock-out for brake adjustment )
Maybe I'll get a little "garage time" tomorrow.
Posted: Sat May 19, 2018 4:27 am
by barrist
A "Little" work getting done.
Top end back together............
One Brake Done, the rear spring clip was replaced after this picture. (Found it Out in the driveway
And the New Thermister installed.
Posted: Sun May 20, 2018 7:56 am
by GasDaddy140
Wow! You really got it going-on with the great Corvair work! I like it
Posted: Mon May 21, 2018 1:50 pm
by Gregory_Miller
Is that the Clark's replacement thermistor?
Posted: Tue May 22, 2018 4:33 am
by barrist
Yes it is, Sorry I had that in another Thread.
viewtopic.php?f=55&t=14180
Posted: Tue May 29, 2018 12:43 pm
by barrist
More Brake Updates...................
L/R Done, One at a time, due to Garage Space Constraints. ( Wife doesn't like her car "Out" overnight)
The "plumbers strap" on the muffler will be replaced on the NEXT Clark's Order.
L/F Started..........
And DONE,
