Odometer
Odometer
Hi fellows, My speedometer works but my odometer does not, any ideas?
Re: Odometer
If you have a Corsa speedometer, the attached article applies directly to you. If you have a Monza speedometer, the information still applies in general. It usually amounts to something like a worn-out drive gear for the odometer. Whether parts are available to fix it depends on what is worn out. Replacement Monza speedometers are usually readily available through eBay, the Corvair Ranch, etc.
I would suggest reading the attached article, and then decide how you want to approach the problem.
- Corsa Speedometer Overhaul - CORSA Communique May 2012.PDF
- (719.1 KiB) Downloaded 72 times
Re: Odometer
Thanks Brad, this will help.
