Then I was told to put more sealer on the bolt below where the oil continue to weep through. This didn't resolve it either. Anyone have any ideas? It's the 3rd time in the shop for this issue.
![Image](https://afdmeq.sn2.livefilestore.com/y2p33HZTy3VWhqrJ2182bR3BI0EO6uGGm2vFkHVWCWo4C6CNYiNkl9DUoihWMxezVSzzKlK0xbtChXx7tjSoL3DYPgcKAtwye7KSxHnvsHFXYrfX7K7Bo_MHs8jgxk-UzNe/IMG_20121119_161917%20%281%29.jpg?psid=1)
I doubt you would need yet another gasket. The gasket would only be damaged and need replacing if you actually physically remove the oil filter/alternator adapter from the rear engine housing. It is usually damaged because it is a paper gasket and tends to stick in place and is damaged/separated and normally is not reusable when it is removed. Also, the gasket forms a seal between the adapter and the rear housing mating surfaces. It helps to seal any slight irregularities between the two machined mating surfaces, and helps to prevent oil from leaking out between the two metal surfaces. IT DOES NOT NECESSARILY CREATE A SEAL AROUND EACH BOLT! The bolt and washer tend to create their own seal when properly fitted and tightened. The bolts do not normally need any kind of chemical sealer, o-ring or gasket. They are installed "dry" or with a small amount of anti-seize compound brushed on the threads to protect the aluminum threads the steel bolt screws into. I have never had any difficulty getting the oil filter/alternator adapter and its associated bolts to seal and not leak. A fresh gasket installed on clean parts, and five 5/16-18 bolts with the threads coated with anti-seize compound and torqued to specs (7-13 ft. lbs.) is all that is needed.corvairdog wrote:Brad, this is an excellent theory. I appreciate all responses. It continues to leak. He applied the sealer to the bolt, let it set for 4 hours and then ran the car at idle for 20 minutes - no leak. I then drove the car for a good 20 minutes and it began leaking from that bolt. I'm going to see if Clark's can send me a new gasket and a bolt and have him try that.
The picture you refer to does not display on my PC. I had noticed earlier that some attempt had been made to embed a picture in your first posting, but it does not display. I tried to copy the associated URL that you embedded and to use it directly on the Web browser, but it comes back with ACCESS DENIED, so the website hosting the picture is probably not accessible because of embedded site security.corvairdog wrote:The picture at the top of this thread clearly shows where the leak is coming from...
The site you have that picture hosted is password protected. You can see it but we cannot. Try to upload it here using the "Full Editor" - "Upload Attachment" feature so we can see it.corvairdog wrote:The picture at the top of this thread clearly shows where the leak is coming from. I ordered a used housing, bolt set and gasket from Clark's to hopefully get this resolved. Car is going back in next Wednesday and I'll update the thread then. Thanks.
