63 Spyder Help
- rv6aaviator
63 Spyder Help
Hi guys,
New to the forum. Need some help. I have a 63 Spyder Turbo. I am getting detonation after 2000 RPM. Distributor, rotor, points, plug wires, plugs, condenser all are good. Vacum is good. Fuel flow and carb adjusted correctly. Had timing set to 24 degrees per manual and also tried 18 to 20 per clarks recomendation. Pressure retard seems O.K but it sure feels like when the turbo starts to kick in and I start getting detonataion that the timing is not retarding.
Any thoughts would be appreciated. Thanks.
Jeff
63 Spyder Turbo
Jeff
63 Spyder Turbo
Jeff Sandor
Prez Cincinnati Corvair Club
62 Convertible
63 Spyder Convertible
64 Spyder Convertible
66 Corsa 140 Coupe
66 Monza Coupe
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
Re: 63 Spyder Help
Flat cam lobes? ![dontknow :dontknow:](./images/smilies/dontknow.gif)
- flat6_musik
Re: 63 Spyder Help
Hi Jeff! Welcome to the forums! So......how did you determine that the pressure retard is working? I'll bet it's not.....rv6aaviator wrote:Pressure retard seems O.K but it sure feels like when the turbo starts to kick in and I start getting detonataion that the timing is not retarding......
- rv6aaviator
Re: 63 Spyder Help
Flat 6,
I took the old one out. I am able to move the retard although it takes some force. I sprayed some cleaner into it, blew it out and put it back in. I'm not sure its good or not. How can it be tested? Tks.
Jeff Sandor
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
- flat6_musik
Re: 63 Spyder Help
Well, if mine, I'd first blow in it to make sure the diaphragm's not leaking. On the air compressor in my garage, I have an air regulator on the output valve that I can adjust from 0 to 110 psi. I would probably connect a small hose to the pressure retard cannister and slooowwwly dial up a few pounds of air pressure and watch it to see if the whole distributor breaker plate is rotating too.
Oh yeah!!! I forgot!! Are you SURE you have a pressure retard cannister and NOT a vacuum advance unit?!? It's happened many times to people who have just bought their turbo cars.....previous owners who have inadvertently installed the wrong distributor by mistake.
- rv6aaviator
Re: 63 Spyder Help
I will try that tomorrow. Thanks. Currently, I can not get the distributor breaker plate to rotate when connected to the retard. The breaker plate moves freely when it is not connected to the retard.
It appears to me that it is a pressure retard unit. Part number on the arm is 250. In Clarks book that part is listed for 65-66 turbo corvairs. 62-64 turbos corvairs should have part number 224 or 231 but its replacement now is the the 250.
Should the breaker plate be in the "forward" position and then move towards the "rear" during operation?
My breaker plate is in the rear position and does not seem to move when RPM's are increased.
Jeff Sandor
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
Re: 63 Spyder Help
Just a thought, have you checked your plugs? When I first rebuilt mine many years ago, the plugs would get fouled until everything seated in. So whenever I got under boost, it would miss and runn terrible. So, I had to blow it out once a week or so. A little bit of driving under boost took care of the plug fouling.
Phil
64 Spyder convertible
- rv6aaviator
Re: 63 Spyder Help
Just put in new plugs today. Drove it about 20 miles today. I am going to put on a few more mile tomorrow and pull plugs and see how they look. The may tell me something.....
Flat6 gave me some ideas on the pressure retard being bad. That's what my gut was telling me today after trouble shooting. But I"m not an expert....lol.
Thanks for the ideas. Keep ya posted.
Jeff Sandor
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
- flat6_musik
Re: 63 Spyder Help
Might also want to double check the stamped numbers on your distributor just to make sure it's for a turbo. It's probably correct. The entire corvair distributor number listing is somewhere on the 'net. I think I posted it here once, but.....who knows where!
Re: 63 Spyder Help
Here is some Corvair distributor ID information:
http://dalemfg.com/dale_024.htm![Image](http://autoxer.skiblack.com/nallm/disdata.jpg)
This downloadable file in Adobe Reader (.pdf) format will provide more informatioin to help you to verify your Corvair distributor.
Distributor Charts for Corvair, 1960-1969
The graphic at right shows the advance weights and the letters A-E referenced below. Also the dimensions of the advance weight springs as refered to below.
These listed numbers below for distributor shafts, cams, and vacuum advance units are the actual stamped numbers on the parts as you find them.
Since all parts 1960 and 1961 and all parts 1962-1969 can be interchanged, there are many non stock combinations of parts. The centrifugal advance timing is controled by the cam, the distributor shaft (the timing control hole varies in size and location, thus controling amount of advance; in conjunction with point cam bottom shape, and interaction with the advance weight shape).
The bottom chart lists the actual distributors used with each engine for each year, both smog and non smog. The number is on the side of the distributor housing and all distributors numbers begin with #1110xxx. Thus, it is the last three numbers which define model of distributor. (Remember, the internal parts might not be origional, just because the housing number is correct).
Vacuum advance numbers begin with #1116xxx, the last three numbers being the ones stamped on the actual vacuum advance arm.
- rv6aaviator
Re: 63 Spyder Help
Confirmed that part number is correct on the distributor. Removed the pressure retard again. Sprayed some penetrating oil into it. Blew it out with a little air. Reinstalled it. Took the aircompressor and operated the retard with it. Moves with about 15 to 20 lbs of air pressure.
Went out and drove the car. Whola!! Running like a champ. Detonation is gone. Still going to install a new retard. Old one in working but it should have a new one.
Thanks a bunch guys!
Jeff Sandor
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
Re: 63 Spyder Help
![Image](http://i538.photobucket.com/albums/ff345/MsMinx08/Smilies/Awesome_mc_HT_Smiley.gif)
Glad to hear that your perseverance paid off!
![Image](http://i538.photobucket.com/albums/ff345/MsMinx08/Smilies/smiley_congratulations.gif)
Re: 63 Spyder Help
![whoa :whoa:](./images/smilies/whoa.gif)
Part number C871R (Regular): 62-66 TURBO DIST PRESS RETARD-NOT ORIG REPRO-FITS ALL YEARS
Note: This part is not a perfect match for cx3169.
Weight: 0 lbs 6 oz
Catalog Pages(s): 51,78(12)
Price: $ 114.40
![doh :doh:](./images/smilies/doh.gif)
http://www.corvair.com/user-cgi/catalog ... IN&page=51
![Image](http://www.corvair.com/gfx/51.jpg)
Part number C7877 (Performance): TURBO ADVANCE/RETARD *SET TIMING TO 18 BTDC
Note: This part is not a perfect match for cx3170.
Weight: 0 lbs 6 oz
Price: $ 155.15
![eek :eek:](./images/smilies/eek.gif)
http://www.corvair.com/user-cgi/catalog ... IN&page=78
![Image](http://www.corvair.com/gfx/78.jpg)
Re: 63 Spyder Help
Great job on the repair! Thanks for letting us know what it was ![good post :goodpost:](./images/smilies/goodpost.gif)
![soapbox :soapbox:](./images/smilies/soapbox.gif)
- rv6aaviator
Re: 63 Spyder Help
Another question....does anybody know how much vacum the engine should be pulling? When I disconnect the vacum line going into the pressure retard and connect it to my vacum gauge, I am showing 15 inches.
When I tested my pressure retard, it takes about 20 psi from my aircompressor to get full travel. A new one is on the way.....
Jeff Sandor
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
Re: 63 Spyder Help
![thumbsup :tu:](./images/smilies/thumbsup.gif)
flat6_musik wrote:Re: Corvair 140 and 180 engines?
... is SOOO critical! You could blow your motor in probably less than 20 seconds of boost if things are wrong. I consider the corvair turbo motors a grenade with the pin already pulled. But I love a challenge! With a 110 or 140 and a few modifications, you can cruise and the engine should always ...
![think :think:](./images/smilies/think.gif)
![angry :angry:](./images/smilies/angryfire.gif)
![assault :assault:](./images/smilies/067.gif)
![:-) ::-):](./images/smilies/003.gif)
