Front brake rotor/drum bearings
- RedLightBrew
How do I remove the inner bearing from the front brake rotor? 1964 Coupe. Thank you.
1964 Corvair Monza 900 Coupe (bought 2012)
1962 Corvair Monza Spyder Convertible (sold 2002)
- RedLightBrew
Re: Front brake rotor/drum bearings
Never mind. Just did it.
For those who may want to know-
I remove the outer bearing (it just falls out) Then I reinstall the castle nut and just pull the drum off.
The inner bearing and seal will just be sitting on the spindle .
- RedLightBrew
I tapped it out with a socket extension. Pops out easily.
