Corvair 65-68 motor NEW T3/T4 TURBO
140 big valve heads, TRW forged pistons
eBay Item No: 110939666663
starrcooke969s
$10,000
Corvair engine block RH which is a 65-68 motor 164 Cu. In. I bought this motor from a customer who was tired of breaking VW trannies. Motor sat for about a year so I will be completely rebuilding it to buyers specifications...either for a Corvair trannie==stock rotation or to a VW trannie==reverse or stright rotation. Motor has 140 big valve heads with ALL NEW U.S.A. made valves, New Norris springs set a @ 115# closed with proper shims. Fresh valve job and hand lapped valves to seats. Seats staked like Bill Thomas of Yenko fame did after chambers and exhaust flowed. Fresh head gasket seating area.0.052 copper head gaskets. Heads are Tri-ported with Chrome intake system. NEW T3/T4 Turbo and NEW 390 cfm Holley carb set up by NASCAR carb Guru..Rick Walker. All NEW Clevite mains and rod bearings, Crank will be Std/Std Nitrated crank that has passed a wet mag and hub pinned to crank and 3/8x24 ARP flywheel bolts.. NEW TRW forged LONG SKIRT .020 pistons with Total seal rings. New reverse or regular rotation Cam and lifters. Fail Safe cam gear. Dial indicated cam to crank. Complete motor balanced. Corvair bell housing or Crown adaptor plate with Hi-Po Corvair or Kennedy /VW clutch/pressure plate and Flywheel. Will install waste gate and exhaust for installation. I expect this motor to make 325 to 375 HP but be drivable in a buggy or street car. Protronix ignition, can be set up for regular oil cooler and stock filter or as is now remote. 37 Amp Alternator that has been polished. Will have Damper Doc. freshly rebuilt harmonic balancer. Deep Otto pan. Offenhauser polished valve covers. Engine top cover is chromed. Freshly serviced late model big fan bearing assembly with Mag fan. Taylor 8 mm silicone spark plug wires. Otto oil pick up Crown type big oil pump set at .004 .Shipping is 250.00 west of Miss. or 400.00 east of Miss. lower 48 only. Please feel free to call Starr Cooke (619) 447-6788 San Diego, Ca. I am the only Hi-Po engine builder Clarks Corvairs recommends.
![cool photos :coolphotos:](./images/smilies/coolphotos.gif)
