REPLACING MANIFOLDS
corvairian1
REPLACING MANIFOLDS
Post by corvairian1 »
I need to replace the manifolds and crossover pipe on my 65 Vair. My question is how difficult is this to do under the car. I hope I don't have to pull the engine out. Any and all advice is greatly appreciated.
"CORVAIRS RULE!"
Bobby65
Re: REPLACING MANIFOLDS
Post by Bobby65 »
no, you don't have to drop the motor, its pretty straight foreward and easy
Drive it like you stole it
65 Turbo Monza Coupe
64 monza convertible 4 spd
Grand Ledge, Michigan
corvairian1
Thanks Bobby65. I plan on doing it next week. I'll keep my fingers crossed that all goes well.
"CORVAIRS RULE!"
cnicol
Post by cnicol »
I'd suggest spraying the manifold studs (two on each side) with penetrating oil every day until you do the job. Your #1 issue will be keeping the studs from twisting off as you unscrew their nuts. Take it easy and slow and you might get lucky!
