Changiing Wiper Arms and/or Blades
- kenshapiro2002
Feel stupid asking such a simple thing but I figured I'd ask before I take the wrong approach and start breaking/bending things. To adjust the angle of the wiper arms I assume there's a nut under the cover on the wiper? On every other old car I've had the end cap swivels up and there's a ut underneath securing the arm to the motor. Thing is I can not get the end to pop up. The car sat for 23 years so it may just be stubborn but I want to check before applying too much pressure.
Also...can't get the blade off. Does the spring tab compress (push in toward the arm), or expand (pry away from the arm)? I think it compresses but again...nothing is moving.
Ken
Ken
Re: Changiing Wiper Arms and/or Blades
there is a spring loaded clip + you have to take the arm spring load off then you just lift off - the spline has a groove at the bottom that the clip goes into - there used to be a wiper arm removal pliers but it seams to be not longer made, clarks list it in error, they do not have it
i have been trying to get one for years, makes it easy to remove and align IF ANYONE KNOWS WHERE I CAN GET ONE, PLEASE LET ME KNOW
1960 700 COUPE
- kenshapiro2002
Ahhhhhhh...so, what implement of destruction do you use when you don't own the magic tool?
a very thin bent screwdriver...but watch the paint
- kenshapiro2002
mart wrote:a very thin bent screwdriver...but watch the paint
Thanks,
Ken
P.S. How do the blades come off?
same here - a wide bladed screwdriver and rotate screwdriver to pry off - again be careful of the paint
1960 700 COUPE
this is easier, pull the thin metal strip away slightlly (where the blade joins the arm) move the arm towards the strip, as if to bend the arm, this releases a little tit (english engineering term) and the two should pull apart. Sometimes a little wiggle (another english engineering term) is required if its stuckkenshapiro2002 wrote:mart wrote:a very thin bent screwdriver...but watch the paint
Thanks,
Ken
- kenshapiro2002
Thanks gents (British).
I have been able to remove a few by hand. have to pull with both hands with equal pressure straight up.
- kenshapiro2002
You talking arms or blades?60vair wrote:I have been able to remove a few by hand. have to pull with both hands with equal pressure straight up.
special tool to remove arms without damage to paint:
spoon
not the bodywork spoon, a plain old tea/soup spoon
spoon
145236 wrote:special tool to remove arms without damage to paint:
spoon
- cvair4life
Also of interest to any/all of you. I recently put 16" Rain X Fusion blades on my LM 66 Corsa and it's a perfect fit. It actually gets more of the windshield than the 15" did and don't hit any trim.
1966 Corsa Coupe
- Phil Dally
Twelve year old post...possible AI Bot Spam.
This is the correct wiper arm removal tool!!
Vairy V8 Rides Again
Zonker Gets Race Motor
Gem is Still my Favorite
LA Angels fan since 1978
Only Own 10 Corvairs Now
Been Associated With Fifty+
- Phil Dally
Okay...maybe not AI Bot Spam!!
