Now that the parts are clean, the fun part can get started. I am using Heavy Duty U-Joints with grease fittings. Grease fitting placement is important for 2 reasons. One, with these style U-Joints, the fitting is in a boss off to one side. You need to be able to get to the fitting when the shaft goes back into the car. Place the fitting to the inside or shaft side so that it will be accessible. Second, the grease fitting should be placed between the drive trunnion and the driven trunnion on each end of the half shaft according to tradition. The story goes that if placed properly, the drive forces will "compress" the grease fitting hole and this is a stronger position. If placed incorrectly, the drive forces pull the hole in opposing directions and create stress that could eventually cause a crack in the area. I will be sticking with tradition. Once again, my 7 year old son is assisting me and photographing our progress.
