Page 1 of 1
Old GM Brake Drums
Posted: Sun May 04, 2025 11:55 am
by Rotary FP46
Corvair brake drums. Part numbers:
3841177
3841198
and
3850106
Not showing up in any of the parts catalogs, on GMPartsWiki, or at Clark's.
Are brake drums like radio parts in that they have their own special catalog?
I'm more or less reasonably sure that the first two numbers apply to LM cars, and that the third number is something small and early, but have no confirmation.
Re: Old GM Brake Drums
Posted: Sun May 04, 2025 5:19 pm
by vairmech
Show a picture with a tape measure somewhere.
Posted: Mon May 05, 2025 7:58 am
by isucorvair
Per the internet
"rear brake drums GM #3841177
(WILL FIT 1970 Nova./1969-70 Camaro w/o 4wheel Disc./1968-69 Nova-Chevelle. /1964-67 Nova-Chevelle-Camaro)"
Posted: Mon May 05, 2025 7:59 am
by isucorvair
Another internet result:
REAR BRAKE DRUM NON FINNED USED 10 12 BOLT REARS CHEVELLE CAMARO 3841198
Posted: Mon May 05, 2025 8:20 am
by 66vairguy
isucorvair wrote: Mon May 05, 2025 7:58 am Per the internet
I recall the Corvair LM rear drum was only on FRONT of the cars you list. Not positive.
Posted: Mon May 05, 2025 9:07 am
by Rotary FP46
All of this is why I'm asking about a separate reference book for the drums.
Will dig the drums back out for measurements once I'm done identifying and cataloguing the camshafts. Limited working space at the moment.
Posted: Mon May 05, 2025 12:24 pm
by RexJohnson
Some drums of that era had different hub hole dia. It might be a good idea to use a Corvair hub to see if they fit?
Posted: Mon May 05, 2025 12:46 pm
by 66vairguy
RexJohnson wrote: Mon May 05, 2025 12:24 pm Some drums of that era had different hub hole dia. It might be a good idea to use a Corvair hub to see if they fit?
Good idea from Rex. There are arguments about the Corvair drums being "lug centric" or "spindle hub centric". As best as I could determine the OEM drums were primarily "spindle hub centric" after fitting stock OEM drums on LM's. Not sure on EM, but the front drums were often riveted to the spindle hub. Folks that remove the rivets have not reported issues with the drums staying centered.
If the drum spindle hub hole is too small, well it won't fit. If too large, then probably the lug holes will keep it centered --- MAYBE!
Posted: Mon May 05, 2025 3:24 pm
by RexJohnson
The drums have to be centered on the hub. Tapered lug nuts can center the wheel but the drum just gets pinched in between the hub and the wheel so it would fall to the bottom before you tightened the wheel. I got some aluminum finned drums off of a later model GM car for the front of a Corvair and the hole was to small. I put the drum in a lathe and opened up the hole and then hub centered it on a Corvair hub to turn it on my brake lathe.
Posted: Mon May 05, 2025 3:32 pm
by Rotary FP46
vairmech wrote: Sun May 04, 2025 5:19 pm Show a picture with a tape measure somewhere.
Front:
Rear:
66vairguy wrote: Mon May 05, 2025 8:20 am
If those forums are to be taken at face value, the Corvair fronts fit the rear of Camaros, and the Corvair rears fit the front of a whole bunch of things. I don't have a way to confirm.
66vairguy wrote: Mon May 05, 2025 12:46 pm Good idea from Rex. There are arguments about the Corvair drums being "lug centric" or "spindle hub centric". As best as I could determine the OEM drums were primarily "spindle hub centric" after fitting stock OEM drums on LM's. Not sure on EM, but the front drums were often riveted to the spindle hub. Folks that remove the rivets have not reported issues with the drums staying centered.
As it turns out, I've come across a crate of LM front spindles.
Seems the 1177 drums I have are hub-centric.
Posted: Mon May 05, 2025 6:31 pm
by RexJohnson
All drums are hub-centric because they have to be centered to the spindle. The lug nuts will not center the drum.
