F/S 1966 Cord 810 in F/B...not mine
(Corvair ads you find on other sites can also be discussed here, i.e. ebay, craigslist.)
Phil Dally
Post by Phil Dally »
I don't believe I've ever seen one of these for sale.
It would be nice if seller posted an engine picture.
https://www.facebook.com/marketplace/it ... dd6a9867ec
caraholic4life
Re: F/S 1966 Cord 810 in F/B...not mine
Post by caraholic4life »
Within the past year, I was a Red Glen Pray 8/10 advertised on either Craigslist or e-bay (I don't recall which) that was one of the 97 cars built (That number includes six prototypes).
After Glen's production ended, another firm built 13 additional Cord 8/10s before the redesigned SAMCO Cord was introduced. The redesigned Samco version was rear wheel drive and offered a V8.
April 2025 Article: http://oldmotors.net/cord-8-10-eight-tenths/
July 2023 Hemmings article: http://www.hemmings.com/stories/replica ... -its-time/
Nov. 2020 Barn Find: http://barnfinds.com/1-of-97-1966-cord-sportsman-8-10/
Photo of Factory: http://libwww.freelibrary.org/digital/item/40923
This is related to one of the few Samco built cars with the Corvair drivetrain.
July 2024 AACA Article: http://forums.aaca.org/topic/418338-196 ... 0-1-of-14/
vairchet
Post by vairchet »
Here's a few photos of a Cord 810 taken at a Rainbow Oaks meet:
Phil Dally
Really good engine picture...thank you Chet.
Anybody got pictures of an 8/10 up on a lift?
Like to know how the heck did they steer it?
vairchet
Post by vairchet »
If I recall, steering was similar to 1966 Oldsmobile Tornado.
Factory shop photo:
Photo taken from Internet
Wagon Master
Post by Wagon Master »
Yet another turbo showing up with a Powerglide. Interesting.
Phil Dally
Powerglide with a turbo motor certainly can be done.
Put a one way check valve upstream of the modulator.
Use an HEI distributor (more fire) with a 5-pin module.
Trigger ground for the 5-pin with a 4 psi Hobbs switch.
The 5-pin retards timing up to 7 degree when ground.
Dennis66
Post by Dennis66 »
No big issue with "turbo and powerglide", when you're custom building, the sky is the limit. On the check valve, couldn't you just hook the vacuum modulator hose UPSTREAM of the turbocharger?
Now my big question: The engine compartment picture shows the engine with the bellhousing / flywheel end of the engine facing forward. How are they connecting to the drivetrain? A special mounting plate to connect to a "regular" transmission?
RexJohnson
Post by RexJohnson »
The car is front wheel drive so the whole drivetrain is just moved forward.
sweet66monza
Post by sweet66monza »
I will have to do some digging for photos, but I powerglide and efi swapped a 140 4 speed one about 5 years ago.
They are extremely homemade looking underneath. Handling was absolutely terrible and the ackerman angle was way further out of whack than anything I had ever driven, steering it was horrible. It was kind of fun as a stock 140/4, but the powerglide ruined it a lot and the holley sniper completely took away any remaining thrill, IMO.
I remeber having to service front cv and wheel bearings and researching parts, they used citroen front wheel drive knuckle assemblies and outer shafts. Steering box was long shaft Corvair.
Cody Hurley
www.cchvintageauto.com
Post Falls, ID
66 monza convertible 140/pg loaded with options
66 corsa coupe 180/4sp 3rd owner
66 Canadian monza coupe 110/pg
65 monza coupe 110/4 daily driver
Dennis66
Post by Dennis66 »
For comparison, here's one that just popped up on ebay. IIRC, only 14 Corvair powered Cords were made by this company.
https://www.ebay.com/itm/205382123408?_ ... R7jWsMPTZQ
caraholic4life
Dennis66 wrote: Sun May 04, 2025 9:54 am For comparison, here's one that just popped up on ebay. IIRC, only 14 Corvair powered Cords were made by this company.
That appears to be the one I mentioned earlier in this thread. I did however get wrong when I thought it had been one of the Glen Pray cars when it appears it was actually a Samco built car.....
Dennis66
Post by Dennis66 »
When I was doing a search for the powertrain, I saw some pictures of this same car. It is a "no expense spared" restoration with the Corvair powertrain completely gone through (140 HP engine). Still, 27K vs 11K...
Nice looking cars.
Return to “Vehicles For Sale”
