Sil-Glyde Which?
Sil-Glyde Which?
Post by Frank DuVal »
I see the comment "I use Sil-Glyde for that" all the time on forums. So which Sil-Glyde do they mean? aka Which one do you use? Lots of choices I see, even on Amazon. Brush, Tube, Tub, Ceramic... Lubricant, brake lubricant, technician grade....AAaaaaaahhhhh! :eek:
I do see it is an AGS product. I remember their first product, the white grease stick for door latches, etc. Shown in GM shop manuals, but with a GM label. American Grease Stick. I am currently using their DOT 5 brake fluid, not in stick form, though. :wink: :rolling:
Lane66Monza
Re: Sil-Glyde Which?
Post by Lane66Monza »
I got my Napa Sil-Glyde from NAPA at the local NAPA store. The original Multi-Purpose Sil-Glyde is made by AGS. Though both are silicone, not all silicone greases are made the same nor do they have same specs and operating characteristics.
AGS Sil-Glyde at Amazon is $9.39. It is moisture-proof and heat resistant to over 425 degrees F (218 degrees C),
NAPA Sil-Glyde at NAPAonline is $13.49. Comment: This is the silicone lube you want to use solely on caliper pins. Safe around rubber boots or any rubber brake components. Also rated at a higher temp (-20 To 500 Deg. F.) than the original AGS formula.
https://www.napaonline.com/en/p/BK_7651 ... d_source=1
Al Lane
Southeast Georgia
1966 Coupe 110 4 spd
Interesting, as Sil-Glyde is an AGS trademark and when you look for the MSDS on NAPA website it is the AGS MSDS. :think:
toms73novass
Post by toms73novass »
I believe the Napa version is the same as the AGS brake formula Sil-Glyde
1962 700 Wagon
1963 Spyder convertable
1965 Monza
1967 UltraVan 211
