NO LONGER NEEDEDWANTED /CAL CUSTOM AIR CLEANER ADAPTORS
Having trouble finding that special part you need? Post a wanted ad.
jmcasaleiz@gmail.com
Post by jmcasaleiz@gmail.com »
Want to buy 4 Cal Custom adaptors used to mount small chrome air cleaners on individual carburetors.Any help appreciated, thank you Duke
Last edited by jmcasaleiz@gmail.com on Thu May 30, 2024 8:42 am, edited 1 time in total.
davemotohead
Re: WANTED CAL CUSTOM AIR CLEANER ADAPTORS
Post by davemotohead »
I just sold a set 2 weeks ago, I guess these were used on some Yenko models, maybe the stage 1 & 2 street versions? I had 3 sets of them and have one set on my Corsa and sold the other 2 sets to Yenko guys. Personally although cool I think they are not that great, they don’t seal well to the top of the carb and the set screw always comes lose and they fall off, I had to drill a tiny divot in the carb body and make a pointed set screw much like the fuel pump bolt so the screw would have a nice place to sit and then put lock tight on the screw so it wouldn’t back out, that seems to keep them on better, Good luck in your search! :tu:
Hi Dave,
Thanks for your input. What aircleaners are you running? Could you send a photo? Thanks, Duke
davemotohead
I put a longer center screw in them and doubled up (Stacked) the air cleaner elements for more flow, you can see the bottom filter in these pics, I also added a PVC system to them. before I did the set screw mod they would always fall off. I sold the other 2 sets for good money to Yenko guys because I thought these things sucked! LOL
corvair parts 210.jpg (76.1 KiB) Viewed 187 times
corvair parts 209.jpg (159.33 KiB) Viewed 187 times
corvair parts 207.jpg (133.39 KiB) Viewed 187 times
corvair parts 208.jpg (153.63 KiB) Viewed 187 times
corvair parts 280.jpg (69.75 KiB) Viewed 187 times
corvair parts 281.jpg (66.88 KiB) Viewed 187 times
corvair parts 279.jpg (66.2 KiB) Viewed 187 times
Return to “Parts Wanted”
