differential cover vent used
scottymac
Post by scottymac »
Using the Clark's Finned Aluminum Differential Cover, what vent/breather are you using?
vairmech
Re: differential cover vent used
Post by vairmech »
If you change the position slightly you can use the plastic push in ones that you can get aftermarket. Or you can put a shield like GM did and put it in the same area.
Ken Hand
248 613 8586
vairmech@aol.com
Corsa Past President
Corvanatics Vice Prez
Chair 2007 Detroit Convention
Phil Dally
Post by Phil Dally »
The vent hat is threaded into the lid with 1/4" or 3/8" pipe threads.
Raise the hat up with a 6" piece of pipe...can't remember which size.
We started doing this in the sixties on our dune buggies...no overflow.
On the racecar I used -4 braided stainless hose to a remote mini K&N.
Vairy V8 Rides Again.
LA Angels fan since 1978
Only Own 10 Corvairs Today
Been Associated With Fifty!!
6" would poke a hole in the body on a car wouldn't it?
Phil Dally
There is about a foot of clearance there.
