Master cylinder started leaking out of the bore.
Probably because of it not being driven enough.
Insert finger wag of your choice here.
M/C is 1" last year of drum/drum base Corvette.
7" Diaphragm is a Classic Performance Products.
CPP bracket is modified...support is fabricated.
I did learn brake fluid is soap & water soluble!!
Adding Summit vacuum can for braking length.
Have one last can of original GM trunk splatter.
Using brake line adapters rather than bushings.
M/C is 9/16 & 1/2 and residual valves are 3/8.
Should be done today, we hope fingers crossed.
New Master Cylinder for Zonker
- Phil Dally
Vairy V8 Rides Again.
LA Angels fan since 1978
Only Own 10 Corvairs Today
Been Associated With Fifty!!
- Phil Dally
Re: New Master Cylinder for Zonker
Back together and I found the correct brake line adaptors.
No finished picture because it is too cold and wet to paint.
I will update when weather is more conducive to painting.
H/F Brake Bleeder review is okay...it works but it is slow!!
https://www.harborfreight.com/brake-flu ... 92924.html
- brakeline.png (41.53 KiB) Viewed 162 times
That HF bleeder is just a vacuum bleeder and I think it would be a lot simpler to just use a hand vacuum pump.
In most cases you still have to wrap the bleeder valve threads with tape to keep from sucking air past the threads.
I do like the looks of that auto-refill bottle. If it works as advertised and doesn't leak, it would save having to continuously checking the fluid level.
That is a beefy looking MC! Have you driven it with power booster? Curious how it will work out. Ken
1965 Corvair Corsa coupe
Rochester, NY USA
Rochester, NY USA
- Phil Dally
Pedal was a little soft...did another bleed today and now the pedal is rock solid.
