Oil slinger on all motors?
I'm in the middle of breaking down a 102hp motor (not sure of the year) and I notice that it doesn't have an oil slinger next to the distributor gear on the crankshaft. Is it supposed to? I'm 99% sure that this motor has been apart before so maybe they forgot to put it back in?
--- 63 Monza 2dr PG ---
St Louis, MO
St Louis, MO
- davemotohead
Re: Oil slinger on all motors?
I think GM Removed it for 62-63 engines and then reinstalled it in 64-69 engines because the 63's leaked, just like the 63 - 3 plate oil cooler that was a complete 1 year only joke, They were always trying to pinch pennies, if it does not have one install one as they are needed.
Thanks for the confirmation. I've ordered one from California Corvairs along with some other odds and ends. Like an 8 row cooler to replace the 3 row that's on there now lol!
This motor is a bit of a mystery. I looked up the head and block numbers and it came up as a 102hp. The car is a 63 Monza PG originally with the 84hp motor (body tag confirms it) so the motor was obviously swapped at some point. It has the 3 row cooler, but also a mag fan and 64 carbs (with the extra vent at the bottom). The bell housing was originally from a manual, but somebody cut (with a torch by the looks of it) the PG ventilation holes in it. Every time I work on this thing I find more surprises lol!
St Louis, MO
St Louis, MO
Whoa- that is one wild looking bell housing
- davemotohead
I would not use that Meth head built bell housing! Get a good one!
It's never going to cool properly. They didn't put the hole in the large space where the "2" is. Dennis
Yeah, I thought you all would get a kick out of that
St Louis, MO
St Louis, MO
With all the different pieces making up a Corvair engine it does invite "creative" repairs and rebuilds. I think the term used is "Frankenmotor".
Check to see if the magnesium fan is the one year only 1964 model "small bearing" unit, or the 65-69 large bearing fan. Those who want originality on a 64 would prefer the 64 fan.
I've bought a few "rebuilt" engines that folks could not get to run and I usually find a mess during disassembly. Fortunately I don't pay much for these "rebuilt" engines and usually get some nice parts out of the deal.
One was a "sand rail" engine that never ran. The heads were 140HP and "rebuilt", but when I CC'd them the compression ratio was 13 to 1!!!!! Gasket surface was cut INTO the spark plug hole threads! Junk. Fortunately I got enough good parts to break even on the deal.
