I'm hoping for some feedback and evaluation of the hot-rodded 140 in my Corsa coupe.
My 140 has forged pistons, a 280 Isky Cam, Pertronix 2 and flamethrower coil, mildly ported heads with the step machined out, mildly modded carbs, and high flow mufflers on stock manifolds and down pipes. I briefly installed headers and did not notice any real difference. As it is I can barely out run my brother in his 5spd Honda Fit sport from 0-60 or 0-70. His car is supposed to run 10.1 seconds 0-60 and a 17.5 second quarter mile so that's about where I am. This is in my 66' Corsa coupe with the 4 speed. My tires are taller than stock changing the effective gear ratio a bit. I had Bryan Blackwell drive my car in detroit to see if he thought it was running like it should given the build.. he said it felt pretty good but that was of course seat of the pants, not measured numbers.
I won't be able to answer a lot of the questions some of you might ask. I started with an engine that it turned out someone else had built for autocross and a lot of the work was already done. When I took it apart I found it was at max bore, had the forged pistons, 280 Isky cam etc. I took the heads to the Corvair ranch to have deep valve seats and porting done (as well as new springs etc.) and Brett told me afterward that the porting had pretty much already been done to the extent that is possible without cutting the heads open for access. Also the step had already been machined out.
I took the engine down most of the way but once I discovered the 280 Isky cam I stopped short of splitting the block (I had intended to put a 270 in). The engine showed no signs of wear so it seemed the previous build had few miles on it. I cleaned everything up and put it back together.
I had my carbs done by Grant Wolf. He did a full rebuild with standard performance mods on all four. Someone had tinkered with modding the carbs before but he said they did a lousy job of it so he fixed them up for me.
I run premium fuel but my timing might not be advanced as far as might be optimal because I have to watch out for pinging. I think my timing is set right where it is supposed to be for a stock 140 by the book.
When making suggestions please take the following into consideration: This car is driven daily about 8 months per year and occasionally goes on long road trips to Corvair events. Also I'm on a very tight budget. The car sounds exactly the way I want it to but it doesn't have the performance to back it up.
![sad :sad5:](./images/smilies/sad5.gif)
Thanks in advance for your time guys!
