I think I have my body tag figured it out aside from the date code. I've read other posts and they refer to the 3 digit date code as being mentioned "later on" but I can't seem to find the reference. " An exception to the 2 digit- one letter code is a 3 digit number code used on 1965 Los Angeles models built in Mid-September 1964. This is discussed later at the end of the Decoding section."
Here is what I think I have:
918 = date code- not sure what date this is aside from "mid-Sept 1964"
65-10537 = 1965 Monza coupe
LOS (covered by wire) = Los Angeles plant
?1171 = body number
TR 713 - black intererior
N-N = maroon paint top/bottom
(1) W - tinted glass (windshield)
2 L S - 4 speed / rear antenna ( I dont have a hole in the RH rear fender and cant find a patch)
3 C - padded dash
4 U - spare tire lock (I dont even have a spare, so yeah...) LOL
Decoding my body tag date code.
1965 Corvair Monza 2 door 4 speed 110hp motor
Re: Decoding my body tag date code.
BODY TAG INFO:
918
Body Build Date: ???
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. "918" Is not a standard format for a Chevrolet Corvair Body Tag build date code.
65-10537 LOS 1171 BODY (Partially obscured by wiring harness)
Style: 65 = 1965 10537: 1 = Chevrolet, 05 = Monza, 37 = 2-Door Coupe 4-Passenger,
LOS = Los Angeles (Van Nuys Plant), California, Production Sequence No: 1171
1965 Chevrolet Corvair Monza 2-Door Coupe - 4 Passenger, Total Production: 88,954
TRim: 713- = BLACK (MONZA 10500 and CORSA 10700 SERIES — Bucket Front Seats)
This 3 digit code represents the interior color and seat type.
Paint: N-N = MAROON "Madeira Maroon Poly."
Lucite No. 4624LH, Rinshed-Mason No. A1711M, Ditzler No. DDL 50700
Example — 1965 Corvair Corsa Coupe in Madeira Maroon
ACC = Accessory line
W 2LS 3C 4U
GROUP 1
W = RPO A02 — Glass, Tinted Windshield
GROUP 2
L = RPO M20 — 4 Speed Manual Transmission
S = RPO U73 — Rear Antenna
GROUP 3
C = RPO B70 — Padded Dash
GROUP 4
U = RPO P19 — Spare tire lock
GROUP 5
NONE
I have attached a copy of the 1965 Chevrolet Corvair GM Heritage Center Specs
- (2.01 MiB) Downloaded 33 times
Pretty sure I nailed most of the decoding aside from the date code of "918".
On one of postings about body tag decoding is this:
viewtopic.php?t=4321
Its referenced on other posts as well, and looks like it may have originated on the other Corvair forum. I looked to see if I could find the original posting, but it may have just been intended to discuss, but missed.
I just couldnt find the "end of the decoding section". Maybe it means 9/18/1964?
Its not that important, but I was just curious if someone had a quick and easy answer.
The gold Monza badge is a nice touch. I'm not a fan of gold trim, but I do like that. I'm assuming it was done aftermarket?
