After too many blown fuses caused by rusty fuse contacts, I decided to swap out the stock 58 year old fuse box with a modern "blade style" panel made by Racers Inc. I had bought this a few months after Clarks first announced they were carrying these, but then I procrastinated, for a few years. I got my butt in gear when I discovered how scary it was to have the windshield wipers suddenly stop during a downpour, from a blown fuse. Here's some shots of this... I highly recommend going this route as the new style of fuses are way more reliable, more consistent and much less prone to rusting.
Blackbox Hp modern fuse panel install, 63 Spyder
Re: Blackbox Hp modern fuse panel install, 63 Spyder
Here's the one I took out... looks like a disaster in the making, and this was the "good side"!!
- flat6_musik
How right you are!....after 50+ years of use, the rusty contacts on the fusebox can give you lots of weird, intermittent problems. Man, yours looks really nice and nearly original in appearance! Sweet!
I also had to replace mine on my '66 Crown car, with a generic model with integral LEDs and lots of available fuses. I put it in the front trunk area, as you can see. (You like that "unblowable" fuse there on the old fusebox? :D )
