Brake pressure differential switch 67-69
erco
Post by erco »
Does anyone sell just the switch that screws into the junction block? Shown in red in attached images.
Re: Brake pressure differential switch 67-69
Don't think so from any Corvair vendor I know of but that small switch might be a part common to other GM vehicles of the era.
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
erco
Post by erco »
Right again, azdave! Turns out it's a whole assembly with springs, pistons and O-rings. That screw-in part is just a fixed electrical contact. A rebuild kit is just $12, I've emailed this company to confirm it fits Corvairs. I'm surprised Clark's doesn't carry these (assuming they fit).
Info page: https://musclecarresearch.com/gm-pd-valve-kit-4
Rebuild instructions: https://www.musclecarresearch.com/gm-3956727-rebuild
$1 seat puller tool: https://www.musclecarresearch.com/brake-valve-seat-tool
brake diff switch.jpg (119.33 KiB) Viewed 263 times
erco
Post by erco »
Owner Scott replied to use a different one:
That looks like this one:
https://www.musclecarresearch.com/1972- ... ve-autopsy
This is the kit for the valve in my article:
https://www.musclecarresearch.com/gm-pd-valve-kit-1
Scott Hollenbeck
Muscle Car Research LLC
erco
Post by erco »
Just ordered a kit from Scott, will advise how it goes. I'm doing everything else to my brakes & front end so rebuilding this switch is the crowning touch. I'm surprised more people haven't chimed in here. Maybe since 90% of Corvairs only have single master cylinders then nobody cares. :chevy:
erco wrote:
Wed Sep 09, 2020 9:19 am
Just not something I have ever needed myself. All of my Vairs are pre-67 and single MC.
65 Corsa 140/4
66 Corsa 140/4
erco
Post by erco »
Yes, that's an enviable motor pool of "early" LMs you have there, azdave!
erco
Post by erco »
I rebuilt mine today, Scott's kit and tool were easy to use with the instructions on his website. My brass piston was fairly seized in the cast iron block. Only change was that I opted to re-use my springs since the ones in his kit were stiffer. Can't test just yet since the rest of the car is scattered, but I am confident that all went well.
nirvairna
Post by nirvairna »
well done erco :clap: :clap: :clap:
