Corsa Speedometer
lalkie01
Corsa Speedometer
Post by lalkie01 »
Is the corsa speedometer the same diameter as a non-corsa speedometer. Thanks Larry
Re: Corsa Speedometer
Not even close. They are totally different animals. the Monza speedo itself is small diameter like maybe 3" ( I do not have one out of a cluster to measure) and mounts into a metal housing on the back of the cluster that also mounts the other gauges. This wide housing then mounts to the back of the cluster face. The Corsa speedo is 4.5" in diameter and mounts directly to the back of the cluster face. Why do you ask?
:think: :idea: Assuming you have some Corsa speedometer problems...
The odometer drive often wears out in these aging mechanical speedometers, and serviceable original replacements are somewhat rare. If you have ruled out the speedometer cable as the source of your trouble, you may find that Corsa speedometer repair is somewhat difficult — as some internal components seem to be made of unobtainium. I have attached a copy of a CORSA magazine article on this subject for your information...
Corsa Speedometer Overhaul - CORSA Communique May 2012.PDF
(719.1 KiB) Downloaded 8 times
:link: http://www.corvair.com/user-cgi/catalog ... w_page=210
:link: http://www.corvair.com/user-cgi/catalog ... w_page=132
Part number C9701: REBUILT 65-66 CORSA SPEEDO
NOTICE: Price includes core value: $60.00. You will be issued a refund of $60.00 when you return the used part.
Weight: 1 lbs 0 oz
Catalog Page(s): 210,U-47
Price: $ 299.60
Aftermarket electronic speedometers may be adapted to the Corsa instrument panel. Corsa gauge mounting plates are available from Seth Emerson's Performance Corvairs...
:link: https://www.perfvair.com/dash-parts-steering-columns/
Contact Us:
Seth Emerson
3462 Kirkwood Dr.
San Jose, CA 95117
Email: Sethracer@aol.com
Phone: (408) 247-2237
:google: :search: :link: https://www.google.com/search?q=electro ... e&ie=UTF-8
Image :link: https://www.vdo-instruments.com/instrum ... meter.html
Image :link: https://www.summitracing.com/search/par ... ner=SREPD4
Image :link: https://www.autometer.com/
Image :link: https://www.jegs.com/c/Gauges-Tachs/10331/10002/-1
The Corsa and Monza instrument panels can develop problems with the electric instruments and/or illumination lights. The panels are plastic, so a metal conductive grounding strap links the electric gauges together and then ties them to chassis ground at a single point. If the single screw that attaches that grounding strap to the metal dashboard becomes loose or corroded, the electrical ground to the instrument panel components may be lost and this can disrupt the operation of the electric gauges and illumination lights.
lalkie01
Post by lalkie01 »
The odometer on my corsa is not working and I thought i could replace it with a monza speedometer. Either that or take the parts from a good monza speedometer and fix my corsa. I didn't want to spend $200.00 to get my repaired but I may have to. Still looking at options. I need to check to see if the inter parts are the same. Thanks for the help. Larry
lalkie01 wrote:
Tue Jun 30, 2020 12:45 pm
Years ago I fixed up a few Corsa speedometers for my car and a buddies cars. The Monza speedometer parts won't work, at least not most of them. I have used modified low mileage Monza speedometer frames with a good main gear combined with new Corsa odometer intermediate drive gear. (Clark's used to sell them). This requires a modification to the Monza speedometer frame to use with the Corsa parts. Also --- anytime you have the speedometer apart you have to magnetically calibrate it. I was lucky and found an old shop who calibrated mine after I fixed them. Basically this is a job for an expert!!!
The Corsa speedometer had a trip odometer so a METAL drive intermediate gear was required. Only problem is once the gear lube dries out the main and intermediate gears wear fast and bind causing the input shaft bearings to wear. First the odometers quit, then the you get noise and an oscillating speedometer needle.
Frankly I wouldn't do one for as little as $200.00. That's a good price if it comes with a warranty.
lalkie01
Post by lalkie01 »
Thanks for the help. It looks like if i want the speedometer to work i will have too throw some money at it. Thanks again. larry
